Cosworth Boost Control
Old Jun 1, 2006 | 10:40 PM
vyper developments's Avatar
vyper developments
Default Cosworth Boost Control
Hi Guys,
I have a stage 3 2WD sapphire, T34, Greens, Bayjoo Chip, 3 Bar, Pace RS500 Cooler, Mongoose exhaust.
I junked the amal years ago on the recommendation of the rolling road operater at that time and having been using the old faithful bleed valve ever since. I have recently been on the rollers due to a new turbo being fitted and now having a problem getting full boost.
I get a spike of 21 psi (which tails off to around 16psi) at 4250 rpm but boost will not increase any more further up the rev range. The bleed valve is fully open and I have a brand new .31 Actuator with the spring done up really tight in an attempt to get the wastegate to stay closed a little longer.
Should I go back to the amal valve or does anyone else have any ideas how to get round this, an after market boost controller maybe?
Thanks, Mike.
Old Jun 1, 2006 | 10:56 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i'd go back to the amal valve personally, with the correct jetting and preload it will hold much more boost than you are seeing,my own holds nearly 2 bar
Old Jun 2, 2006 | 07:37 AM
foreigneRS's Avatar
foreigneRS
Testing the future
could be your wastegate penny no longer seating properly
take the wastegate off the actuator and fix it closed by other means. then carefully drive it and see if boost increases higher than it did before. i'm sure i don't need to tell you what could happen if you drive too hard with the wastegate fully closed
if it doesn't boost harder, you know it's a wastegate problem, not a control problem
Old Jun 4, 2006 | 05:35 PM
vyper developments
Thanks for your replies,
The turbo is new and I checked it all out prior to fitting so I would not have thought it be a wastegate problem.
I will try a reworked amal valve like bud-weis suggested, anybody have any ideas how I go about re- jetting it?
CheeRS, Mike.
Old Jun 9, 2006 | 01:32 AM
Manet's Avatar
Manet
I dont know the condition of your engine, but it could also be high backpressure, causing the wg to open. High backpressure, because of an worn engine, bad rings, valves, headgasket etc.
original
Apr 28, 2026 05:20 PM
Kyle Langford
27
Aug 5, 2019 07:54 PM
gchristophi
Aug 31, 2015 10:36 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
