Hot start s2
my starter motor wouldnt work when my engine got hot and i found some time ago that a heat sheild was missing, so i got one and fitted it with a different starter, since then my cars been in the body shop but now i got it back and i could try it, car was idling on my drive for abit and when i turned it off and on again the starter motor locked slightly then kicked in!
i think it wont work at all like last time if the car was hotter
the heat sheild i put on seems small and clips on to the pipe, is this defo the only sheild for the starter?
ive seen some starter sheilds in burtons cateloge that cover the starter, should i try one of these mayb?
Originally Posted by John Laverick
Have you checked the wiring supply to the starter?? Could be fried as well as the old starter? Maybe worth re-wiring??
my heat shield wraps round the soliniod and the body of the starter (covering every thing,
it holds it self on by sorta bieng so tight on the motor it cant come of and a zip tie to the wires
havnt had a prob since fitting
il give them a check then or mayb move the wires away abit if i can
