Changing the TPS on a 3dr cossie
Old Jun 1, 2006 | 04:29 PM
Moonstone Kev's Avatar
Moonstone Kev
Default Changing the TPS on a 3dr cossie
Does anybody know how easy it is to change the TPS on a 3dr cossie & does it have to set up again. cheers
Old Jun 1, 2006 | 05:10 PM
robbyridz's Avatar
robbyridz
TPS normally side on side of throttlebody, there is just 2 bolts - and there is no setup to be done
Old Jun 1, 2006 | 05:35 PM
abdr500's Avatar
abdr500
yes ther is a set up to be done on the tps but a engine set up no and is a cunt of a job because you need a very short screw driver to get to the 2 littel screws
Old Jun 1, 2006 | 05:59 PM
andymaac's Avatar
andymaac
just unbolt hole throttle body
Old Jun 1, 2006 | 08:28 PM
Moonstone Kev
Yea i thought that m8, but do you just line up the new one in the same position as the old one.
Old Jun 2, 2006 | 06:53 AM
Dave Henshall's Avatar
Dave Henshall
you will probobly find that the position of the old one is almost exactly in the middle of the elongated holes on the TPS,,,, no more clues...
Old Jun 2, 2006 | 09:19 AM
robbyridz's Avatar
robbyridz
i didn't realise u had to setup tps, I best setup mine!
Old Jun 6, 2006 | 05:02 PM
white cab's Avatar
white cab
if you dont set it up how is the ecu to know when you have WOT?
you can normally set it up using a volt meter set on ohms, but i dont know what the readings are!
ford efi engines i belive reset themselves when you replace the tps.
Old Jun 7, 2006 | 11:16 AM
Dave Henshall
not the webber ecu's though.... these need setting and then if its a P* learning aswell..
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
dombanks
Sep 21, 2015 08:38 PM
