t3 internals
Old May 31, 2006 | 08:56 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
Default t3 internals
this a 270 or 360??
i'd say 270 but 360 had been mentioned
gonna buy a rebuild kit ya see and need to know if a std 1 will do
Old May 31, 2006 | 09:00 PM
Rick's Avatar
Rick
thats a 360.
They dont normally wear that bad (thrust bearin)
U wont get a 360 as part of a kit - u'll need to buy it seperate.
Have a look at the shaft too. If it's blackned it's probably past rebuild time.
Old May 31, 2006 | 09:25 PM
1.9 xr2 on 40's
st170 breaking
sod no rebuild for this then, Ł40 ill give it a go Ł130 and it'll sit in the bin
i dont think its worn just loads of play in the bearings (think i can get away with a bearing kit and leave teh thrust bearin?)
there was tons of play but blokereconned it wernt smokin
shaft is nice
Old May 31, 2006 | 09:26 PM
1.9 xr2 on 40's
st170 breaking
may just list the seperate parts of the turbo on ebay cos all the threads were spot on and it werent actually very old either
Old Jun 1, 2006 | 12:47 AM
SafeChav's Avatar
SafeChav
If theres play in the shaft then something has to be worn, be worth checkinf the hole in the front alloy plate, if theres play that could of enlarged and thats what the front oil seal lives in aswell.
Are the bearings very loose on the shaft in the places they run, bear in mind there will always be a little play as they are wet floating bearings, but not too much.
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
