engine pics please
Old May 29, 2006 | 09:25 PM
a7fco's Avatar
a7fco
Default engine pics please
could you post up your yb engine pics close ups would be better as ive just put a new motor in my 3 door and i need to know where some of the vacume pipes and the amal valve pipes go
cheeRS guys
Old May 29, 2006 | 10:06 PM
bud-weis's Avatar
bud-weis
Football Cwazy
vacumm pipes from memory should be.....1 from map sensor to side of inlet manifold (don't intersect this with dump valve take off or anything), and 1 from fuel pressure regulator. and probably 1 more for standard breather if you still have it.
amal valve pipes are...R port goes to the airbox or is vented to atmosphere if you don't have 1,W port goes to the actuator and the C port goes to the turbo compressor housing.
hope that helps
Old May 29, 2006 | 10:12 PM
a7fco's Avatar
a7fco
cheers martin
still post up your pics please
Old May 29, 2006 | 10:15 PM
bud-weis's Avatar
bud-weis
Football Cwazy
no probs...
here's a couple of mine if it helps??
Old May 30, 2006 | 03:35 PM
a7fco's Avatar
a7fco
thanks again martin
Old May 30, 2006 | 04:35 PM
cozzie4d's Avatar
cozzie4d
here's some more, with the vacuum pipes
(fuel press reg, dumpvalve, inlet..)
JoeyBoyden
Jan 4, 2024 02:36 PM
bigryrs
Mar 28, 2016 09:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
