Headgasket for 375 Bhp Escort
Old Aug 8, 2004 | 07:27 PM
cosworthbg's Avatar
cosworthbg
Default Headgasket for 375 Bhp Escort
What headgasket for 375 Bhp cosworth and what bolts?? It's supposed to run 2 bar boost! It will have and 50 bhp shot of nos!
Old Aug 8, 2004 | 07:28 PM
GARETH T's Avatar
GARETH T
i would use a gen wrc headgasket with standard head bolts
Old Aug 8, 2004 | 07:29 PM
TIFF's Avatar
TIFF
Chasing Radders
Mountune 4 Layer WRC HeadGasket, Expensive but worth ever penny.
Standard FORD head bolts
Cometic Gaskets have been getting a slating at the moment as a few people including me have had Damaged ones from the factory and have damaged some engines...............steer well clear.
Old Aug 8, 2004 | 07:40 PM
Disabled Account's Avatar
Disabled Account
Good advice above....
But IF you were on a tight budget, and could be in a situation where you may want to remove the head to check on condition (especially with NOS fitted)...i.e. check fir signs if detting.wear etc, then I would "O" ring the bock (can be done in situ) and use the cheap as chips late Escort Cossie head gasket YB1261 (I think that is the part number)...............I only say this because if you take off the head when a WRC gasket is fitted you've blown £ 280.00
With wire rings fitted the cost of replacing then and fitting a new late Es Cos gasket is aboutt £ 28.00 - 34.00 total
Old Aug 8, 2004 | 07:43 PM
cosworthbg's Avatar
cosworthbg
Thank's guys,and is the 3 layer headgasket good enough or it should be 4 layer at all costs???
Old Aug 8, 2004 | 08:01 PM
TIFF's Avatar
TIFF
Chasing Radders
Fuck me, if you can get them for that i will have 10
Try £380
Old Aug 8, 2004 | 08:08 PM
Disabled Account
Try £380
Well, thats even more reason to go the "O" ring route, as you only pay for the machining of the grooves ONCE....Then, no matter how many you remove the head you are quids in everytime!
About 4 months ago, PJ Motorsport were selling those late Es Cos gaskets for £ 4.98 on special offer
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
englandbrad
18
Aug 6, 2015 09:24 PM
