L8 To P8
Old May 28, 2006 | 03:21 PM
costina's Avatar
costina
Live long and prosper!!
Default L8 To P8
What can a P8 do that a L8 cannot?
Old May 28, 2006 | 04:00 PM
DazC's Avatar
DazC
ALS, WI, closed loop boost control....
Unless you get the L8 updated by RPlabs (speak to Mike R) when the conversion becomes commercially available...
Old May 28, 2006 | 06:46 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as above
there is basically nothing that the p8 can do that an l8 can't if the run program is very cleverly written, although it does have more memory space for more break points in the maps
Old May 28, 2006 | 08:22 PM
costina's Avatar
costina
Thanks nick good useful info as always
Old May 31, 2006 | 06:57 AM
Mr 19"'s Avatar
Mr 19"
So if you run 403:s, it,s easier to map the lowdown revs and idle speed then? Is it possible to map it to go with lambda and cat with a P8 box, compared to a L8? I`ve heard different opinions about this.
Old May 31, 2006 | 07:37 AM
foreigneRS's Avatar
foreigneRS
Testing the future
closed loop fuelling using a lambda sensor is possible (and standard) on both P8 and L8 ecu's, depending on the code written in the run program on the 'chip'
lowdown revs and idle speed fuelling can be largely taken care of by the closed loop
Old May 31, 2006 | 09:39 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
L1, 6 & 8 Can run Air injectors, WI
