alarm!!
Old May 27, 2006 | 06:47 PM
dj22y's Avatar
dj22y
Default alarm!!
does anyone know where the latch sensors are on the boot and the bonnet,
my concept 300 alarm keeps giving out 4 cherps saying the either one is open????
anyone got any clues what to do??? cheers
Old May 27, 2006 | 07:43 PM
cos jon's Avatar
cos jon
When i had my clifford it did nothing but pi$$ me off, never get one again !
I suppose if you tell us what car then we may be able to help !!
Old May 27, 2006 | 10:05 PM
SafeChav's Avatar
SafeChav
The boot should use the factory switch for the boot light, and the under bonnet one is usually visible if you have a look
Old May 28, 2006 | 11:36 AM
dj22y's Avatar
dj22y
sorry guys its a FRST. tell you what its starting to fucking piss me off tho!!!
intermitant piss of poo!!!!!!!
Old May 28, 2006 | 11:38 AM
SafeChav's Avatar
SafeChav
Sledge hammer...........you know it makes sense
Old May 28, 2006 | 11:50 AM
dj22y's Avatar
dj22y
sledge hammer yes!!!! but no alarm after the fun!!!!
i dont even know what the fucking alarm box looks like!!!!
Old May 28, 2006 | 11:51 AM
SafeChav's Avatar
SafeChav
You won't need an alarm after the sledge hammer.....thats the sheer beauty of it
The box will be up under the dash somewhere, black metal box with a clifford sticker.
No offence but those Concept 300's are shit alarms
Old May 28, 2006 | 11:56 AM
cos jon's Avatar
cos jon
On the rear there is a copper pad on the section that runs along the width of the boot (the latch conects here too) these can start to get a film on them which stops the contact being made, get some 1500 grit glasspaper and clean them so there bright copper. Also worth doing this to the 4 pins in the boot which connect to the pads.
The front pin switch is a big block near the chassis plate. Its more than likely that the alarm fitter would have put another one on somewhere but it will be on the slam panel somewhere.
Chances are the alarm box will be under the drivers area (above the pedals) its just a black box saying clifford.
Old May 28, 2006 | 11:57 AM
dj22y's Avatar
dj22y
roger that!!!!! fucking thing!!!! will have a look at it!!!! might have to buy myself a pit bull and tie it to the car!!! shud work better!!!!
SafeChav's Avatar
SafeChav
And just to expand on that, put some electrical contact grease on them aswell
Old May 28, 2006 | 12:01 PM
cos jon's Avatar
cos jon
Yep copper grease too
I had a clifford 300 and it was $hit, never again.
Old May 28, 2006 | 12:03 PM
SafeChav's Avatar
SafeChav
Ive never owned one but my mate had one on his Astra SRI and while left to sit it just broke one night, never to work again.
I bought a Toad myself after lots of opinions, VERY good and reliable, doesn't have all the extra little bits like a clifford does out the box but are a damn sight cheaper and can be readily bought
Old May 28, 2006 | 12:07 PM
dj22y's Avatar
dj22y
i can hear a big RRRRRRRRRiiiiiiiiiiiiiiiiiiiiipppppppppppppp when the fucking thing come out thats for sure!!!
but might just try wot you said...but after my heavy nuight last night it might take me a while!!!
red stripe give you a bad head!!!!!!!
Old May 28, 2006 | 12:11 PM
cos jon's Avatar
cos jon
Mine was the motion sensor that even on the lowest setting would still detect something, used to go off everynight, at work, in carparks. Had to start turning the motion sensor off everytime which defeated the object of having one !!
I also had the problem you describe even after sorting all the bits including door pins.. ....
Old May 28, 2006 | 12:17 PM
dj22y's Avatar
dj22y
where the motion senser then???? might have a gander at that!!!
Old May 28, 2006 | 12:21 PM
cos jon's Avatar
cos jon
Could be anywhere mate, mine was mounted under the gearstick gaitor to the carpet. I think it may need to be somewhere quite centra to the car.
You'll know when you find it cos it has a red LED on it with a light grey plastic flat screw head (so you can adjust the sensitvity). Also says motion sensor in it (its about an inch sqaure)
I found mine by luck !!
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Rammer46
Sep 18, 2015 08:31 AM
Iain Mac
Sep 13, 2015 09:16 PM
jdsjojo
Aug 26, 2015 10:09 PM
