Oil Found in Boost Pipe
Old May 27, 2006 | 05:46 PM
JohnnyT2's Avatar
JohnnyT2
Default Oil Found in Boost Pipe
Was cleaning engine bay with a mate on his series one yesterday. Took the boost pipe off between the intercooler and the crossover and found some oil inside it and the crossover pipe.
Is this normal, or is the turbo on it's way out?
Old May 27, 2006 | 05:54 PM
Micky's Avatar
Micky
Its normal if you re breather is standard.All the best ,Micky
Old May 27, 2006 | 05:56 PM
JohnnyT2's Avatar
JohnnyT2
Thanks for your reply.
What's special about the oil breather then? How does an uprated one stop oil in the boost pipes?
Old May 27, 2006 | 06:08 PM
Micky's Avatar
Micky
Basically the standard breather has a pipe running to the bottom of the fuel distributer from the cam cover.This is there to burn off any oil vapour rather than dumping it on the road.On an uprated breather system this oil vapour would would be caught in a catch tank.I wouldnt be worried about about the oil you've found as its 100% normal.Regards Micky
Old May 27, 2006 | 06:12 PM
JohnnyT2's Avatar
JohnnyT2
Brilliant. Thanks for your help.
Old May 27, 2006 | 07:30 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Although oil up there is a sign of either turbo wear or piston ring wear etc.
Old May 27, 2006 | 08:24 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
As long as it's not too much oil, then I wouldn't worry too much. You could also flush the intercooler to get rid of any risidual in there.
Any pics of the S1 btw ?
Old May 27, 2006 | 10:14 PM
Rick's Avatar
Rick
Christian and Beccy
Nah, the std breather is wank, will always have some oil being sent down to the metering head.
RSCossieGaz
Sep 1, 2015 09:20 PM
YODI
Aug 30, 2015 01:12 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
frug
Aug 26, 2015 06:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
