How to fit a dump valve to an escort rs turbo
as above not sure what im doing what vacume hose do i need and what size T.piece
I tryed to use one from a boost guage and it didnt work
plesae help me thanks
a 5-6mm vacuum hose is ample for it with a 2mm inside diameter
goes from the dump valve to the right hand side of plenum t piec it into there! u shouldn't have any loose pipes
if uve connected it to the ecu pipe thats ok but if the car stalls then uve got the wrong dump valve for the job a rs turbo needs a twin piston dump valve!
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
