crankshaft sensor / phase sensor? symptoms of a fooked one?
Old Aug 8, 2004 | 01:55 PM
DaveEscos's Avatar
DaveEscos
Default crankshaft sensor / phase sensor? symptoms of a fooked one?
if it was knackered, it wouldnt only make the car misfire on full boost would it???
also what does the phase sensor do? how can i check it. Iv eheard of people re-gapping / syncrosnising it
Old Aug 8, 2004 | 02:12 PM
Damo V's Avatar
Damo V
Clearances
TDC sensor to pulley teeth.............. 0.6 to 1.0 mm
Dizzy cam to phase sensor..............0.2 to 0.3mm
Prob just remove em, check curent flow with ohmeter or summat though I dont know how lol... clean up the faces with wd40 or summat, refit and gap???
You can see the phase sensor obviously has to be pretty accurate, and be careful as thewires probably are very brittle now.... Im sorry if they werent such delicate (when old) parts and easily buggered up..I wouldve run down to swop em over mate. But I dont fancy my chances lol
Old Aug 8, 2004 | 02:21 PM
Disabled Account's Avatar
Disabled Account
Dave,
Easiest way is to beg, steal or borrow one from someone and try it. There must be someone on here that can loan you a known good working one for an hour or so????
That way you will know within minutes if the sensor/brittle wire has a fault or not.
Old Aug 8, 2004 | 03:24 PM
DaveEscos's Avatar
DaveEscos
aye doug, big bad benn to the rescue
hopefully that will find the prob
Old Aug 8, 2004 | 04:08 PM
AndyRST's Avatar
AndyRST
Yeah, its just what is benn wanting for helping? He's always wanted a pretty boy like you
Old Aug 8, 2004 | 04:55 PM
Damo V's Avatar
Damo V
Ahhhh thats alright, his car is in a million bits anyway
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
