water temp meter
hy
i just put the motor back into my s2 and now when i turn the ignition on the water temp meter instantly goes way above the red mark.
everething else works fine, and the fan cut's in normal
where does this temp meter thake it's readings from?
thanks ( grtz from belgium )
guyver
The fan is independant for the gauge (meter)
what is happening, is that for some reason the wire between the gauge and sender (sensor) is earthing. It is unlikely to be the sender itself, more a problem with the connection along the way.
i had the same fault a couple of months ago. it turned out that the contact inside the rubber that connects to the head had gone rusty. my temp gauge would only work when it wanted to. it should be an easy fix though matey.
Mark RS
Oct 12, 2015 06:01 AM
