Cos 4x4 Overfueling proplem
Old May 24, 2006 | 09:21 PM
2ndGear's Avatar
2ndGear
Default Cos 4x4 Overfueling proplem
my 4x4 cos is overfueling, is there any known concerns?
Old May 24, 2006 | 11:15 PM
jon@work's Avatar
jon@work
Coolant Temp Sensor Checking - info courtesy of Simon @ SECS
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) Check resistance between pins 29 and 11. Should be 800 to 5000 ohms (depends on temp). If outside this range, check sensor and/or wiring.
Old May 25, 2006 | 07:46 AM
boost mad's Avatar
boost mad
coolant temp is the blue sensor at the back of the head on the inlet side
Old May 25, 2006 | 07:55 AM
Alvyn's Avatar
Alvyn
could also be the map sensor or the fuel regulator! what spec engine you running?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
