Cossie Cam Belt Changing
Old May 24, 2006 | 12:04 PM
Xindi's Avatar
Xindi
Default Cossie Cam Belt Changing
When changing the Cam Belt on a 2wd Cossie Lump,how'd you guys set the cam belt tension? I ain't paying Ford's fancy prices for a cam belt tensioning tool.
What make are pp8 plugs btw?
Any help would be HUGELY appreciated
Old May 24, 2006 | 03:07 PM
baker p's Avatar
baker p
i just do it by feel....... which cant be explained realy. a tensioning tool is peanuts compared to a rebuild should you get it wrong
Old May 24, 2006 | 06:27 PM
tim10_10's Avatar
tim10_10
Apparently the tensioning rule is that you shoul be able to twist the belt 90degrees on the longest straight if you cant its too tight if it goes loads more its too slack.
Old May 24, 2006 | 08:11 PM
costina's Avatar
costina
Live long and prosper!!
as above but recheck after two full turns of crank aswell to b sure
Old May 24, 2006 | 09:19 PM
Simmo's Avatar
Simmo
The pp8's are Motorcraft jobbies...
Old May 25, 2006 | 12:41 AM
Xindi's Avatar
Xindi
Thanx for the help guys,much appreciated once again
Nearly fell over when I got the price of the tensioning tool from Ford over £200 quid +VAT
Old May 25, 2006 | 07:38 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Originally Posted by tim10_10
Apparently the tensioning rule is that you shoul be able to twist the belt 90degrees in the middle of the longest straight if you cant its too tight if it goes loads more its too slack.
It might be obvious to some, but just to clarify
Worked for me twice so far
Old May 26, 2006 | 01:24 PM
Dave Henshall's Avatar
Dave Henshall
as abvove... the pp8's are actually nipondenso ones rebadged as motorcraft
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
cameron2
Aug 25, 2015 07:18 AM
taylora1409
Aug 12, 2015 12:06 PM
