t34 from 2wd to 4wd???
Old May 23, 2006 | 03:43 PM
gibbo frst's Avatar
gibbo frst
Default t34 from 2wd to 4wd???
hi all.. basically i have a new t34 with .48 exh fitted to my 2wd and my mate has a 4wd with the .63 exh but feels really laggy can my turbo be fitted to the 4wd without swapping the manifolds.. its just he wants to try a smaller one to see if it makes his car any more responsive.. i wolud just say to drive mine but its off the road .. cheers..
Old May 23, 2006 | 04:01 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Yes mate the turbo will still fit without changing the manifold, but you do need to seperate your turbo and spin the housing round a bit, i have a 2wd manifold for sale if he wants to make me an offer on it
Old May 23, 2006 | 06:18 PM
gibbo frst's Avatar
gibbo frst
cheers ill let him no....
Old May 24, 2006 | 12:31 AM
jon@work's Avatar
jon@work
Not quite that straightforward unfortunately -
the (standard) 2wd turbo housing has 4 studs that mount through 4 holes in the manifold;
the 4x4 manifold has 4 studs that pass through 4 holes in the 4x4 turbo housing.
Cosnada
Jan 7, 2016 05:30 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
