What Spark Plugs??
Whats the best set of plugs to use for a 2wd Cossie engine running :-
T34 Turbo
BD14 Cams
803 Injectors
Group A 044 Fuel Pump
L6 ECU
205 Block (can't afford a 200 block
Forge Motorsport RS 500 Intercooler
Just building the engine up now and wondered what the best would be
Any help from you guru's out there would be great
T34 Turbo
BD14 Cams
803 Injectors
L6 ECU
I use pp8 escort cossie plugs set at 0.6 mm 329 bhp 328 lbft
Same spec as yours but standard cams and 4x4 cooler T35
every conversion i have done for people i use these and never had a problem
Nice to see it when finished
deathrider666
Sep 28, 2015 06:12 PM
