amal valves...ow do u pipe them up?
any 1 know where the pipes go 2 off the amal valve as its being disconnected and i wna set it back up n take off the bleed valve turbo distroying cack??
good man....
right on the pipes u push hose over the r letters...
C .... for compressor housing
W.... for waste gate (aka actuator)
A.... atmosphere (metering unit of if u gone efi leave no hose on it
then it wil need to b set up using the little white jets inside it!
