Definitive list of what may turn the warning light on?
Old May 22, 2006 | 05:22 AM
Coxy_UK's Avatar
Coxy_UK
Default Definitive list of what may turn the warning light on?
Does anyone have a list of all the possible parts or problems which may cause the warning/handbrake light to come on?
Thanks
Old May 22, 2006 | 07:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
handbrake switch (or wire shorting to earth)
low brake fluid (or connector on float level not connected)
maybe more, but that's something to go on
Old May 22, 2006 | 11:43 AM
CosKev3's Avatar
CosKev3
As above
Pretty sure thats all it can be
Have you had centre console out/screwed anythin down onto transmission tunnel????
Only reason I ask is that the wire to the switch on the handbrake runs along the tunnel under console,and as said above is a switched earth,so anythin breaking/sticking into wire would put light on
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
