The start of the rot?
May 21, 2006 | 07:11 PM
although im positive its surface (how many times has that been said)
May 21, 2006 | 07:22 PM
its been said all to often
...aslo how many times has the "surface rust" been repaired in the past?
May 21, 2006 | 07:23 PM
Get it done asap keep it at bay for longer, you wont necessarily have to have the entire roof painted may be able to get it localised.
May 21, 2006 | 07:44 PM
Thats nothing peter dont worry
May 21, 2006 | 07:46 PM
Quote:
yeah, i guessed it wasnt, but its unsightly and wouldnt mind it sorted. i think i'll take a trip to moorlands to get a quote.
May 21, 2006 | 07:49 PM
never been repaired b4, thats the 1st sign in 17yrs that rust has appeared on the roof
May 21, 2006 | 08:28 PM
If you were to remove the headlining you would see the true extent of the rot..........and should be your next move IMO
You will probably find the sunroof recess is also rotting as per normal
May 21, 2006 | 09:22 PM
is that the tail gate???
May 21, 2006 | 09:55 PM
Quote:
Quote:
Originally Posted by petermintrst
never been repaired b4, thats the 1st sign in 17yrs that rust has appeared on the ROOF
May 21, 2006 | 10:04 PM
is the lining easy to remove?. that will be my next job
May 21, 2006 | 10:08 PM
yuo wont see much as there's 2 or 3 skin's there.. i've fixed this same bit on my m8's s2.. we had to cut out the rot and wld in new metal.. i've got pic's somewhere..
May 21, 2006 | 10:09 PM
May 21, 2006 | 10:10 PM
well it worth doing as the rest of the car is rust/rot free. no, really it is.
May 21, 2006 | 10:13 PM
[img]
[/img]
cut out filled and welded..
May 21, 2006 | 10:15 PM
so did it start in the same place as mine is?
May 21, 2006 | 10:18 PM
just on the hinge?? then yup..
May 21, 2006 | 11:32 PM
a good bodyworker would make sure the whole roof is painted
May 22, 2006 | 07:54 AM
so, anyone any ideas how much this could cost, best (small patch) and worst (rotten roof) senario
May 22, 2006 | 11:00 AM
PMSL
In a word, yes, very easy
P.S i am known to tell the occasional lie
May 22, 2006 | 03:49 PM
could'nt really say how much it would cost. but at least your roof will be red again.. the bit on my m8's car was a lot worse than that.. it had bubbled right up. you might be lucky an cought it in time.. get to a decent body shop asap..
May 22, 2006 | 04:16 PM
yeah, cheers cossie69. they just look like stone chips that have gone rusty so i might be ok as u say. certainly my next job though. was going to go stage 1 but that can wait i think
May 22, 2006 | 06:15 PM
Hi i have had the same problem but much worse, and have been quoted 500 for the roof. 1500 for the whole car. But looking for cheaper deals after next MOT.
May 22, 2006 | 06:38 PM
have u any pics mate? just so i can gauge price for mine
May 22, 2006 | 07:19 PM
Dont forget when it comes to bodywork, cheap money, cheap job..........
May 22, 2006 | 07:42 PM
i'll be using moorlands regardless of price, within reason.........
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Sep 6, 2016 11:10 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
