Turbo conversion S2 to S1
Old May 21, 2006 | 03:53 PM
White RS1600i's Avatar
White RS1600i
Default Turbo conversion S2 to S1
Has anyone put a s2 mfi turbo lump into a mk3 escort before ?
Are there any bits i need to look out for ?
Also they have different intercooler piping, can i use the s2 piping and s2 intercooler ? or do i have to switch everything to s1 ?
Old May 21, 2006 | 04:12 PM
notSteveS2's Avatar
notSteveS2
gear box mounts r different... u usin mk 3 or mk4 gear box???
engine mounts are different too i think....
awot intercooler u usin?
s1/s2??? standard or after market?
Old May 21, 2006 | 04:17 PM
Moonie's Avatar
Moonie
S1 radiator does not have connection for turbo coolant feed.
Old May 21, 2006 | 04:23 PM
White RS1600i
Ive got two complete whole cars ie the turbos complete and the xr3s complete. I was going to use the standard 4 speed box just to keep it a bit original.
Intercoolers an aftermarket pace jobby just till i can afford a front mount.
Could i get the turbo running in the mk3 with all the bits i have or do i need to sorce extra bits ?
Old May 21, 2006 | 04:25 PM
notSteveS2's Avatar
notSteveS2
hmmmmmmmmm
think u can use all the s2 engine turbo rad IC and managment... but need to use S1 box roll bar etc....
also need to use xr engine mounts an s1 gear box mounts...
i think!
Old May 21, 2006 | 04:33 PM
White RS1600i
Sweet! So i only need to track down some series 1 gearbox mounts ? even though im keeping the standard box ?
Old May 21, 2006 | 07:26 PM
tim10_10's Avatar
tim10_10
If your keeping the standard mk3 box you wont need new gearbox mounts.
Old May 21, 2006 | 08:32 PM
SafeChav's Avatar
SafeChav
Wheres theres a will theres a way, MK3 gearbox will make your life easier, ive got a S2 rad and IC in my MK3 cabby, if you use a S1 rad it is very simple to run water cooling off the standard rad, just pipe work. piece of piss to fit to fit the S2 rad though, engine mount is the same, gearbox mounts are different becuase the box is different.
What do you think a S1 is? A MK3 Escort i believe
Old May 21, 2006 | 09:02 PM
nigel b's Avatar
nigel b
mk3 and mk4 engine mounts are different(s2 is higher)
Old May 21, 2006 | 09:20 PM
notSteveS2's Avatar
notSteveS2
engine mount is different... as sed above and i sed earlier...
if u turbo charge ur car u will probably kill that standard box...
id put S1 box in it matey!
Old May 21, 2006 | 10:06 PM
cossie_wona_b's Avatar
cossie_wona_b
the alternator r diff 2 m8 wiring wise -ifink??
Old May 22, 2006 | 10:54 AM
SafeChav's Avatar
SafeChav
Yeah did i argue the fact?? No i just said gearbox mounts to clarify it a little more.
Are you talking to me about the gearbox?
Old May 22, 2006 | 10:56 AM
SafeChav's Avatar
SafeChav
Alternator wiring is exactly the same, i'm not even sure if S1's had a 70A item, pretty sure they are 55A. Bigger will never hurt though
Old May 22, 2006 | 08:49 PM
notSteveS2's Avatar
notSteveS2
nope not bout box...
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
