diff hanger?
Old May 21, 2006 | 10:18 AM
moonstone mike's Avatar
moonstone mike
Default diff hanger?
AS title
Im replacing my shocks and springs and fitting polys and would like some views on an upreated diff hanger!!
is it worth buying one??
how much?
who sells them??
Old May 21, 2006 | 09:50 PM
CosKev3's Avatar
CosKev3
Fitted one to mine over the winter
Tightens rear beam alot,not tryed the quarter mile yet but supposed to make a difference
Available from Mike Rainbird on here
Bit more diff noise/vibration is only downside
Old May 21, 2006 | 09:57 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Looks proper bufty Kev
Old May 22, 2006 | 11:15 AM
moonstone mike
Great stuff....any idea on price?????
Old May 22, 2006 | 11:26 AM
CosKev3's Avatar
CosKev3
Cheers m8,well worth the hard work
Think they are around the Ł130 mark m8
Bought mine from america,cost me Ł100 but then got stopped at customs and had to pay shit import tax of nearly Ł20
This country sucks
Old May 22, 2006 | 05:16 PM
cossie604's Avatar
cossie604
ggr also do them...seen them on their ebay shop for around the 130 mark also.
Old May 22, 2006 | 09:37 PM
moonstone mike
so the million dollar question IS IT WORTH GETTING ONE??????
Old May 22, 2006 | 10:09 PM
cossie604's Avatar
cossie604
Going on that and the fact that they are quite a cheap upgrade (in cossie terms of cheap lol) i'd say yes...worth getting and i'll be getting one for mine as my standard jobby is about fooked.
Old May 26, 2006 | 08:15 PM
Mr C's Avatar
Mr C
Yes worth getting, pulls the diff up tight, less sagging and wobble, only marginal increase in road noise. BUY ONE! I have heard there is also a solid mount available from the manufacturers if you have solid beam mounts too. Mc2 Racing in the USA, I imported one also but sold it on for a custom solid one before getting to fit it, wouldnt hesitate if thinking of buying again. R+B and GGR have them if you dont want hassle and wait of import.
Old May 27, 2006 | 01:12 PM
All4it's Avatar
All4it
http://www.mc2racing.com/products/xr...ngs/index.html
Old May 29, 2006 | 08:23 PM
rinus_2005's Avatar
rinus_2005
I noticed on that website also a solid diff mount. Tough it requires solid beam mounts. That means a rosejointed rear beam?
If so, I don't have budget for that anyway. So that polybushed one looks like it'll do a fine job.
Which one would be better/stiffer: this new style one or a ( second hand) 909 motorsport group N one?
cheers
Old May 29, 2006 | 08:44 PM
CosKev3's Avatar
CosKev3
cheers
You can solid mount a standard beam m8,the solid alloy mounts that they make just replace your standard/poly bushes
Not sure how much luck you would have finding a groupN/A mount
Old May 29, 2006 | 10:26 PM
rinus_2005's Avatar
rinus_2005
It'll be for a trackdaycar, so the stiffer the better.
Actually atmo the rear is fully polybushed (besides diff hanger)
Got myself a set of toe-in shims of R&B. And got 2 camber adjusting shims fabricated by a m8 of mine to reduce camber to -1 (is now -2, and -1 is recommend for trackuse?)
These still however need to be fitted soon before next trackday.
Besides the above geometry alterations, I'd like to stiffen up the rear some more. When pulling out of corners i can feel the rear swing/wobble/sway/ or however i should discribe it
So adding a solid diff mount would improve stability in the rear end?
Anyone selling the solid kits (including solid mounts) in the uk?
About those solid mounts, there the same as all my powerflex but then out of steel/alu? pics anyone?
lol, too many questions perhaps, but for a newbee in the cos scene all hints/help are greatly appricated
ps. my english isn't that good, so maybe i misunderstand. The beam mounts, they mean all the mounts on the rear beam? or some part of the rear beam?
Old May 30, 2006 | 03:50 PM
CosKev3's Avatar
CosKev3
The solid mounts are made out of alloy and fit into the beam the same way as standard/poly bushes fit
E-mail/ring Mike at R&B and ask him about the solid diff mount,he stocks the poly version so would think he could get a solid one for you
The poly one is very stiff though,hardly any movement at all
Old May 30, 2006 | 07:01 PM
Mr C's Avatar
Mr C
OK the rear beam is mounted by a rear diff mount and the two donuts at the outer edges, these 3 points must all be the same spec, all3 poly or all 3 solid. Marco has sold solid beam mounts, JC motorsport and A1 RallySport too I believe, get these if you go solid diff mount. I would for track use Ask Mike at R+B while you are at it, Im sure he can sort you out a proper set up
Old May 30, 2006 | 07:53 PM
Grayson's Avatar
Grayson
I am the one that engineered the mc˛racing aluminum & polyurethane diff mount.
The diff mount is a tremendously important mount to upgrade, and it is often overlooked. On our autocross Merkur XR4Ti, we were having a lot of trouble with rear suspension deflections - which in our case was on the order of inches. We minimized this problem by installing a Group N (909) diff mount, and I have been a HUGE fan of the Group N diff mount ever since. Last year I wanted to pickup a second Group N diff mount, but when I went to order one from GGR I discovered that Ford had discontinued them! To the drawing board I went.
Now, I modeled the aluminum & polyurethane diff mount after the Group N diff mount. The critical dimensions are 100% identical, and the effective stiffness and NVH are identical. I went through several test bushings with a variety of different durometers and tolerances before selecting the one that is currently in production. I can say based on first-hand experience that you can not tell the difference between a vehicle equipped with a Group N diff mount and one of our diff mounts, which means that I accomplished my goal.
Of course, our diff mount has many advantages over the Group N diff mount since I don't have any bean counters watching over my shoulders like the Ford engineers do. Our mount is about half the weight, yet is quite beefy. Our mount is also cheaper. I paid $180 (Ł97.3 today) for my Group N diff mount 5 years ago, yet I sell our diff mount for $160 (Ł86.5 today). Finally, you can replace the bushings. When the Group N diff mount goes bad, it's bad forever. When our mount goes bad, you just stick in two fresh bushing "halves", which cost about $25 (Ł13.5 today) total.
We do have the solid diff mounts available also, but those are for cars that do not see street duty at all. If you ever drive your car on the street, use a polyurethane diff mount. If you never drive your car on the street, use a solid diff mount. It's that simple, and there are no exceptions.
I just finished up a design last week for a weld-in plate and sleeve kit to allow the rear beam to be solid-mounted for a much lower cost than using alloy beam mount bushings. The kit includes two upper circular weld plates, two lower circular weld plates, and two stepped center sleeves. The material is 4130, which is very strong and easy to weld. This is a better solution than alloy beam mounts, as it is cheaper and stronger. Alas, it is not a reversible modification.
We do manufacture alloy beam mount bushings upon request - I keep material on hand at all times so that I can make them in a hurry - but they are not cheap. We use a billet design that does not use any of those retarded spacer rings, so there is gobs of machine work involved. They do go in nice though, and of course this modification is reversible.
Pretty much everything people have said in this thread has been sensible. Good job guys!
Grayson
www.mc2racing.com
Old Jul 24, 2006 | 07:44 PM
Grayson's Avatar
Grayson
By the way, for those of you that were waiting for the latest batch of polyurethane diff mounts to be made, they're finally ready. The anodizer finally nailed the exact light blue color that I wanted this time around, so I'm pretty excited. I was out of stock for about 2 months since you guys drained my inventory so unexpectedly. We should be good for the rest of the summer at this point.
Those weld-in solid beam mount plates & sleeves that I mentioned in the previous post are also ready, in case anyone cares.
Grayson
www.mc2racing.com
Old Jul 25, 2006 | 06:59 AM
dojj's Avatar
dojj
Resident Wrestling Legend
so, just to clarify, yo wouldn't recomend using the solid mount on a road car BUT if we were to buy the poly one it CAN be made into a solid mount if we fit the metal where the poly is supposed to go yes?
any pics of the solid beam mounts? and when you say it is an unreversable mod, does this mean they'll be welded in as opposed to bolt in jobs?
cheers
Old Jul 25, 2006 | 02:51 PM
Grayson's Avatar
Grayson
I wouldn't convert the poly diff mount to a solid mount. Seeing as there is a solid diff mount available off-the-shelf, there is no point in taking a non-solid diff mount and converting it to a solid one.
The beam mount weld kit is irreversible in the sense that it is welded in place. Of course, you could remove it by grinding the parts off, but I doubt anyone will ever do that. There are some pics of the weld kit at the below link. Just click the picture to view the "large image", which displays a collage of views.
http://www.mc2racing.com/products/xr...592/index.html
Grayson
www.mc2racing.com
Old Jul 25, 2006 | 03:08 PM
dojj's Avatar
dojj
i see what you mean
i've already got poly bushes in the beam so i supposed i'll be better off getting the poly mounts
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
