HELP HELP HELP ! MAP SENSOR QUERY
Old May 20, 2006 | 10:38 PM
JamesVTS's Avatar
JamesVTS
Default HELP HELP HELP ! MAP SENSOR QUERY
Hi all, hopefully u guys can help me...................
ive got a 2bar map sensor off a fiesta rs turbo/std cossy etc etc
and need to know what pins A,B and C are on the connector so can wire it up to a car im turbo'ing,
also is any one using one of these map sensors with a ERL MF2 INJECTOR DRIVER? if so which colour wire on the mf2 has to go to the sensor if any?????????
as much info as poss be much apreciated. thanks all
Old May 21, 2006 | 06:51 AM
szabyk RST's Avatar
szabyk RST
Default Re: HELP HELP HELP ! MAP SENSOR QUERY
MAP:
A:5 Vdc
B: GND
C:Signal OUT
Old May 21, 2006 | 10:17 AM
foreigneRS's Avatar
foreigneRS
Testing the future
if you're a gold member, you could find the information below in the tech essays archive https://passionford.com/forum/viewtopic.php?t=63256
APS 02/03 - 05/01
Air pressure sensors, 2.0 /3.0 bar absolute
The APS xx series devices are high-accuracy and reliability analogue absolute pressure sensors.
Each pressure sensor exploits the piezo-resistive properties of silicon devices. The sensing element is a Wheatstone bridge located on a mechanically shaped silicon chip. A thick film hybrid circuit for signal amplifying is included in the same package. The same circuitry provides thermal compensation and noise reduction.
These active devices are housed in hermetically sealed plastic protective casings.
Technical data
Mechanical Characteristics
Dimensions (maximum) 77,5x65.0x41.0 mm
Nozzle diameter. 4.7 mm
Weight 88.0 g
Connector Mini-Timer 3 way
Performance Pressure range:
APS 02/03 17 to +216 kPa
APS 05/01 17 to +308 kPa
Operating temperature range -30 to +110°C
Response time less than 7 ms
Over pressure
02/03 200 %
05/01 450 kPa
Electrical Characteristics
Power supply 5.00 Vdc ±0.5
Output (min pressure) (at 5 Vdc supply) 0.25 V
Output (Full scale) (at 5 Vdc supply) 4.75 V
Protection Short circuit
APS05 Sensor output In mV (15.46 mV / kPa)
308 kPa = 4750 mV
162.5 kPa = 2500 mV
17 kPa = 250 mV
APS02 Sensor output In mV (22.61 mV / kPa)
216 kPa = 4750 mV
116.5 kPa = 2500 mV
17 kPa = 250 mV
Connector Pin Out
Important wiring note:
The connections A,B & C are identified as 1,2 & 3 on many commercially available minitimer connectors and may also be numerically reversed.
Looking towards the sensor so that the nipple is facing you, and the single mounting hole is at the top, the connector has 2 locating 'blocks' at the top,
(one at each end of the connector) and a single one in the middle at the bottom. Pin A (or 1) is on the Left, Pin B (2) in the centre, and Pin C (3) on the right.
PIN description
A + 5 Vdc
B GND
C Signal OUT
Also see:
https://passionford.com/forum/viewtopic.php?t=30245
Old May 21, 2006 | 03:35 PM
JamesVTS's Avatar
JamesVTS
cheers guys
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
