fiesta rst problem maybe electrical dont know
Old May 20, 2006 | 02:58 PM
daversturbo's Avatar
daversturbo
Default fiesta rst problem maybe electrical dont know
my fiesta rst has a problem when u start the car up it is fine sometimes but then all of a sudden it drop below 1000 rpm splutter and loses its power and the car wont rev up properly. when i am driving the car it does not feel like the turbo is coming in and u can hear it spluttering from the exhaust then it will cut out sometimes can anybody help me please i have fitted a new fuel pump and sender but has not cured it
Old May 21, 2006 | 09:33 AM
gup's Avatar
gup
Default cutting out
alright fella have you tried checking your plugs as it could be spark related try your plug gaps or check that your leads are not arking out cheers
Old May 21, 2006 | 10:03 AM
SafeChav's Avatar
SafeChav
You're guna have to start from the top on this one, as gup says check plugs and leads. You as may aswell give it a good service to eliminate as many things as you can.
Old May 21, 2006 | 10:11 AM
nthorpey's Avatar
nthorpey
get a gauge on the fuel rail and check the fuel pressure. Also check the voltage across the fuel pump when running and also at battery. anything less than 12v and you have no chance.
if this is ok check all pipes and fittings are tight in engine bay and from fuel pump to engine bay. have you also changed the fuel filter?
Old May 21, 2006 | 12:36 PM
jayRS's Avatar
jayRS
is it chipped? if so take it out and try it without it.
check for vac leaks and for the sake of a tenner i would advise a new fuel filter as its prob over due for one.
let me know what things you have checked/changed and how and we're go from there.
Old May 21, 2006 | 12:38 PM
SafeChav's Avatar
SafeChav
Originally Posted by jayRS
is it chipped? if so drop it out and try it.
Thats it you just come storming in after ive done all the dirty work
I'm tellin Nicki about you
Old May 21, 2006 | 01:03 PM
jayRS's Avatar
jayRS
but i am the man who knows about FRST's ive had mine 8 years
Old May 21, 2006 | 01:04 PM
SafeChav's Avatar
SafeChav
In that case i wont be expecting to see any help posts or questions asked from you then
Old May 21, 2006 | 01:18 PM
jayRS's Avatar
jayRS
you dont do ya....
stop getting off topic, you do it all the time chav people will dread up replying as it will be the never ending thread
Old May 21, 2006 | 07:21 PM
daversturbo
ok lads checked leads and they are fine i have changed coil pack fuel regulator and edddis unit still spluttering like a twat can't even get it to tick over now as for a fuel filter it has never had one since the 3 year i have owned it lazy i know will but one tomorrow and put it on thanks for the help
Old May 21, 2006 | 08:12 PM
SafeChav's Avatar
SafeChav
Sort it out, get a new filter on it and some plugs if they haven't been done
Could do leads aswell, don't be a scrooge
Old May 21, 2006 | 11:09 PM
jayRS's Avatar
jayRS
filters dont need changing very often, book says every 60k i do mine every 20k.
have you tried cleaning the ISCV out?
Old May 22, 2006 | 09:43 AM
daversturbo
busy getting a fuel filter on now i have changed plugs and leads will clean iscv and let u know cheers
Old May 23, 2006 | 04:43 PM
jayRS's Avatar
jayRS
dont forget to de-pressurise the fuel system by removing the fuel pump fuse and cranking it over.
remove fuel cap to get rid of tank pressure too.
that way it wont piss all over the show when ya undo the filter
maybe i should of said about that before
let us know how ya get on.
Old May 23, 2006 | 06:31 PM
SafeChav's Avatar
SafeChav
You pussy, its only a bif of fuel man
Letting the side down or what
Old May 23, 2006 | 07:11 PM
jayRS's Avatar
jayRS
fuck off you , i had me fair share of fuel in the mouth, eyes up the nose down the arm etc hang on......... good point hows it taste daversturbo
only joking dave.
not letting the side down chav, just waiting for you to fill in what i missed
missed it that time round though ah , jay 1 chav 0
Old May 24, 2006 | 02:33 PM
daversturbo
need a fuel pump lads anyone got one for sale
Old May 24, 2006 | 02:38 PM
jayRS's Avatar
jayRS
just sold one
i do have another in the shed i took out a mates car as he said it was fucked, but im sure it works as if i remember right i tested it at the time can check it if ya get stuck mate.
it might even be a uprated one as the connections on the top are different but theres no markings to say as such.
and if ya running beiges you need a uprated pump BTW mate.
Old May 24, 2006 | 02:46 PM
daversturbo
yeah could u check for me please mate how much do u want for it are u registrered to paypal
Old May 24, 2006 | 02:57 PM
daversturbo
anyone know if a fuel pump from a rs 1800 non turbo is the same as a fiesta turbo
Old May 24, 2006 | 03:37 PM
SafeChav's Avatar
SafeChav
Just looked on microcat and the Turbo pump appears to be the unique one
Old May 24, 2006 | 03:50 PM
jayRS's Avatar
jayRS
dont worry about microcat.
yeah the part numbers are different but they fit and work and work fine, a few people i know run xr2i pumps, and belive me your be fine, as the 2i and FRST use the same injection system inc the injectors, its just the regulator thats adjusted different so the 2i 1.6/1.8 ans rs1800 pumps will work fine.
if ya running beiges you need a uprated pump mate.
once i checked the pump i will let ya know., but i can only dry test it mate by buzzing it over on a battery
yeah i got paypal mate, as for price, once ive tested it ill let ya know and you can make a offer dude.
Old May 24, 2006 | 04:05 PM
SafeChav's Avatar
SafeChav
Sorry but i have to disgaree there the Turbo pumps are different! An XR2i one will not supply enough fuel.....
Old May 24, 2006 | 04:16 PM
daversturbo
i believe they are the same mate cos i bourght a brand new one once for a xr3i cabby and when it came it had on the box xr2i/xr3i/rsturbo/fuel pump
Old May 24, 2006 | 04:19 PM
jayRS's Avatar
jayRS
dont mean to piss on ya fire mate but it does, trust me i have a few mates running 2i pumps in there FRST's i even runs a 165 chip, he's had it rolling roaded and fueling fine...
the 2i/frst pump is good for this, if ya going 195 chip its not.
anyhow, if you buy a after market pump the 2i and frst have the same parts numbers as its not the pump pressure that is different its the bottom part that differs a tiny bit
Old May 24, 2006 | 04:24 PM
daversturbo
cheers mate great help
Old May 24, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
The turbo pumps have a sticker on them identifying them as turbo pumps though.......
And you look on microcat and the turbo pump is the one thats singled out. It may well work but you're blatantly raping it
Old May 24, 2006 | 04:49 PM
jayRS's Avatar
jayRS
na not raping it, both pump are able to deliver the same pressure
Old May 24, 2006 | 04:51 PM
daversturbo
ive got 2 rs turbo pumps don;t know where your looking mate cause they have no sticker on them at the end of the day the pump is still running a 1.6 engine the turbo has nothing to do with fuel
Old May 24, 2006 | 04:59 PM
jayRS's Avatar
jayRS
the turbo engines do run the fuel at a different pressure, but this is adjusted by the regulator, not the pump.
Old May 24, 2006 | 05:05 PM
daversturbo
safechav stop repling to these posts as u are talking poooooooooo i can smell u from here
Old May 24, 2006 | 06:16 PM
SafeChav's Avatar
SafeChav
That was a bit harsh
Jay, i know the pressure is regulated by the pressure regulator, i may look thick but im actually not
I'm sooooooo sure the pumps different. Its the fact of how much fuel the pump can deliver under full load, thats when it makes the difference, same pressure, but faster consumption!!!!
Old May 24, 2006 | 06:23 PM
tim10_10's Avatar
tim10_10
Just out of interest is it ofab or ofac not that it makes much difference but my mates did similar thing on an ofac one and was the map sensor. This is definitely unique to the turbo tho.
Old May 25, 2006 | 12:14 AM
jayRS's Avatar
jayRS
right, taken from auto data itself, these are the details for the pumps on the fiestas.
xr2i 1.6
delivery pressue 5.0 bar
regulated pressure with vac 2.3-2.5 bar
xr2i 1.8 zetec
delivery pressue 3.0 bar min
regulated pressure with vac 2.5-2.9 bar
FRST
regulated pressure with vac 2.9-3.1 bar
all i could get on the RS1800 was regualted pressuer WITHOUT vac
2.5-2.9 bar
so you see a xr2i pump is fine for use, and really you shouldnt need to adjust the regulator just by changing the pump.
maybe the FRST uprated pump is a 2I pump
Old May 25, 2006 | 11:58 AM
SafeChav's Avatar
SafeChav
Hang on hang on, thats even worse, that auto data has to be wrong Why the hell would a N/A engine have a higher delivery rate than the Turbo. They use the same injectors man
If those delivery pressures were the opposite way it would make perfect sense. higher delivery pressure, regulated to both near enough the same, but the Turbos have more potential for a high fuel consumption.
It gets more and more confusing
Old May 25, 2006 | 09:26 PM
jayRS's Avatar
jayRS
fucks knows mate its the right way round as i wrote them down and just double checked it.
dont forget the turbo says 3 bar min mate
Old May 25, 2006 | 09:39 PM
SafeChav's Avatar
SafeChav
I give up
Old May 25, 2006 | 10:30 PM
jayRS's Avatar
jayRS
jayRS 2 chav 0
Old May 25, 2006 | 10:32 PM
SafeChav's Avatar
SafeChav
I said........i give up, not. you win.
So, thats that point deducted, plus that other one you didn't actually win.
AND im giving myself a point for your utter and sheer gay like qualities.
SafeChav 1 - 0 GayRS
Old May 26, 2006 | 06:56 PM
cos jon's Avatar
cos jon
When i had my fiesta turbo, i had intermittant splutter like you describe, has it got a supechip ??? which is fitted at the bottom of the ecu ??, if so take the car out with a mate and as your driving get him to push the chip towards the ecu and wiggle it. Mine had a loose connection on the pins.
Worth a shot !!!
