ZVH help
Old May 19, 2006 | 11:05 PM
shreevy's Avatar
shreevy
Default ZVH help
i want 2 make a zvh non-turbo this is going 2 go into my 1.6 xr2i.i will use the 1.6 head and a 1.8 zetec engine but i dont no wot else i need 2 carry out this conversion.any help would be great ful
dale
Old May 20, 2006 | 10:42 PM
The_turbo_doc's Avatar
The_turbo_doc
you need to use a lean burn head but mod the inlet for the injectors pal
Old May 21, 2006 | 11:12 AM
shreevy's Avatar
shreevy
still none the wiser lol.dont i need different engine mount head gasket etc
Old May 21, 2006 | 11:57 PM
xr2.0zetecturbo.'s Avatar
xr2.0zetecturbo.
dont think its gonna be worth doing considering the time/money and bhp gain if any,and not wanting to put youre conversion down but it would be cheaper and more cost effective to put a frst conv on or similar from what ive seen,considering the power gains and ease of power increases just with chipping etc,seen lots of 1.8 and 2.0 zvh or 2.1 as they almost end up,conversions and you gotta go the whole hog to get the power up,pistons etc will be as much as the build for a good set,not an expert but have a look at some of the zvh conv and ask them,its not cheap by far,although some ive seen are quality,but that does come with a price,work out youre budget and ask 4a recommended tuner/builder off here or another member on here with similar builds 4 detailed advice,
Old May 22, 2006 | 12:08 AM
dash's Avatar
dash
mad for it did a conversion kit Ł199.99 includes everything you need, burton have started selling parts for the conversion too
Old May 22, 2006 | 07:00 PM
Turbosy's Avatar
Turbosy
If u aren't going 2 turbo it, apart from the lean burn head, u'll need -
water pump adaptor, CVH water pump, CVH crank pulley, CVH bottom (alternator) pulley, CVH head gasket'll do, longer head bolts, 1.6 CVH cam belt, 1.3 CVH cam belt tensioner, CVH water pump gasket & Zetec water pump gasket. U'll need the CVH alternator bracket & modify your engine mount.
This link'll help u -
http://www.quantums.info/zvh.htm
I've got most of that 4 sale. PM me if u r interested.
SY
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
