efi HELP!!!!!!!!!!!!
Old May 19, 2006 | 08:03 PM
NEWTON's Avatar
NEWTON
Default efi HELP!!!!!!!!!!!!
hi,just woundering if any one can help,ive put fiesta turbo ofab management on my s1 turbo it all started fine,come to start today,and it wont theres no spark all ive done is put the water hoses on and put water in it as its a restore,can any one help cheers
Old May 19, 2006 | 10:17 PM
SafeChav's Avatar
SafeChav
Blown fuses? Plugs loose/fallen off?
CPS is worth a check too
Old May 19, 2006 | 10:21 PM
NEWTON's Avatar
NEWTON
pump all primes up getting fuel,so might be cps,would that cause no spark cheers
Old May 19, 2006 | 10:22 PM
SafeChav's Avatar
SafeChav
If its not reading the timing marks then yes, does the pump run when you crank?
Old May 19, 2006 | 10:24 PM
NEWTON's Avatar
NEWTON
yes,its all fine turn the key and you can here it cheers
Old May 19, 2006 | 10:28 PM
SafeChav's Avatar
SafeChav
So the pump primes initally, and pumps while you are cranking it over?
Old May 19, 2006 | 10:29 PM
NEWTON's Avatar
NEWTON
yes mate
Old May 19, 2006 | 10:31 PM
NEWTON's Avatar
NEWTON
is the fiesta rs turbo cps the same as the xr21?
Old May 19, 2006 | 10:32 PM
SafeChav's Avatar
SafeChav
Sounds more in depth then than the CPS. Im still learning about EEC IV but im sure the pump shouldnt run when cranking if the CPS signal is lost.
Old May 19, 2006 | 10:35 PM
NEWTON's Avatar
NEWTON
ill try new cps tomorrow is the xr21 one the same as fiesta rs?
Old May 19, 2006 | 10:36 PM
SafeChav's Avatar
SafeChav
Yes it is.
They are easy to test, save you buying another one.
Old May 19, 2006 | 10:39 PM
NEWTON's Avatar
NEWTON
cheers mate thanks for your time ill give it a whirl tomorrow,its just been doing my head in
Old May 19, 2006 | 11:32 PM
SafeChav's Avatar
SafeChav
Old May 20, 2006 | 11:01 PM
NEWTON's Avatar
NEWTON
still no luck tryed cps still the same
Old May 20, 2006 | 11:10 PM
SafeChav's Avatar
SafeChav
I thought as much, cos the fuel pump runs as i said. Fault finding time.....Probably a wiring fault to the coil pack.
Old May 21, 2006 | 02:40 PM
NEWTON's Avatar
NEWTON
or a fooked coil pack,you havent got a diagram on edis have you?
Old May 21, 2006 | 02:58 PM
SafeChav's Avatar
SafeChav
I doubt both coils have gone, that would be very unlucky. I have a diagram but its on paper...
Old May 21, 2006 | 03:07 PM
NEWTON's Avatar
NEWTON
dont you think both would have gone? carnt you get that diagram to me? cheers mate
Old May 21, 2006 | 03:09 PM
SafeChav's Avatar
SafeChav
It would be unlikely you have a fault on both coils, its a little coincidental. I dont have a scanner or anything. Don't you own a Escort or Fiesta Haynes?
Old May 21, 2006 | 03:11 PM
NEWTON's Avatar
NEWTON
only got escort one,i need to buy fiesta one,is there anyware on the net that may have it
Old May 21, 2006 | 03:25 PM
SafeChav's Avatar
SafeChav
If you have a later escort manual it may cover the EFI models, wiring is near on the same, the EDIS circuit is identical
Old May 21, 2006 | 03:38 PM
NEWTON's Avatar
NEWTON
cheers mate,ill have a look
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
