No boost?????
Old May 18, 2006 | 09:24 PM
turbo.jon's Avatar
turbo.jon
Default No boost?????
Just put turbo back on car went for spin up road and its not running any boost at all turbo not even spinning and exhaust is louder than normal...It sounded and done the same thing on me old mans turbo when actuator bar fell off ive checked mine and bar is all connected.im running a bleed valve not amal valve.the car ran fine before i took it turbo off i only had a stud drilled out which had snapped in housing so dont no why its done this???? would it do it if there is not enough load on the actuator even though im running a bleed valve?????
cheers
jon
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
