can someone take a pic for me of this on there RS!!
Old May 18, 2006 | 11:40 AM
Lincolndanny's Avatar
Lincolndanny
Default can someone take a pic for me of this on there RS!!
Hi guys, just putting my brake crosslinkage back together(the black bar along the back of the engine bay) and i cant rememeber how the spring goes behind the servo. I know it goes over the white bush but where do the spring ends go? Could someone pleeeeeeeeeease take a piccy for me of theres
Thanks in advance!!!
cheers
Danny
Old May 18, 2006 | 12:38 PM
SafeChav's Avatar
SafeChav
Alright mate
The longer edge of the spring hooks on the peg of the transfer bar, and the other leg of the spring hooks over the bracket, you have to put it in and then twist the transfer bar (it is pre-loaded)
Old May 18, 2006 | 12:56 PM
Lincolndanny
cheers mate, but im thick, need a pic
so the longer peg clips round the front or the back of the peg, and where about does the other clip go on the bracket?-the bottom of the bracket?
Old May 18, 2006 | 01:06 PM
SafeChav's Avatar
SafeChav
Jesus christ you are thick aren't you
Microcat would be sooooooooooooooooo helpful now
I'll see if i have time to take a pic. Cant you see where theres marks where the spring touched before?
Im confusing myself thinking about it now
THANKS
Old May 18, 2006 | 01:10 PM
Lincolndanny
no cos its all been powder coated
should the spring be trying to pull the peg towards the bulkhead or away from it. I thought it was to pull the peg away from the bulkhead, but if its the other way round then i get how it goes
Old May 18, 2006 | 01:15 PM
SafeChav's Avatar
SafeChav
The spring pulls the transfer bar towards the bulkhead (so with no servo on there the pedal should be sat as it normally is). You have to turn it about 1/4-1/2 when the spring is located correctly to install it all
Old May 18, 2006 | 01:18 PM
Lincolndanny
right wheres that spring-im off to have a go, and ill take a pic so you can tell me if its right
SafeChav's Avatar
SafeChav
I dread to see what you come up with
Old May 18, 2006 | 01:27 PM
Lincolndanny
thats gotta be right surely
Old May 18, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
oooooooooooooooooooooooooooooooooooooooooooooooooo o
Arc at you with all the shiny bits
Old May 18, 2006 | 04:37 PM
Lincolndanny
ive gotta get it as mint as possible becuase A) im a tart and B) the better nick its in, the more i get for it when i sell it to get an S1
Old May 18, 2006 | 04:44 PM
SafeChav's Avatar
SafeChav
And C) so that every component on the car out lives the shell
Very nice, wasn't that hard was it
Old May 18, 2006 | 04:49 PM
Lincolndanny
how dare you diss my minty mint shell
no wasnt hard at all
I can rebuild engines etc, and build an RST from literally a shell, but you ask me to get a brake linkage spring the right way round
Old May 18, 2006 | 11:09 PM
biglee's Avatar
biglee
Audio specialist
fookin hell, if its all as good as that pic then i will swap my s1 with ya.....
its up for £4500.
https://passionford.com/forum/viewto...hlight=biglees
Old May 18, 2006 | 11:44 PM
SafeChav's Avatar
SafeChav
Impotence
I mean...........incompetence
Old May 19, 2006 | 12:53 PM
Lincolndanny
its up for £4500.
hold your horses, ive gotta enjoy it first
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
griffo69
Oct 4, 2015 11:58 AM
locum8
Oct 1, 2015 01:50 PM
