removing camshaft
I bought a s/hand polished head a little while back which had a kent cvh 35 cam in it.
I plan to have it skimmed and checked over before i fit it so i started stripping it down earlier.
Its completely stripped but cant get the cam out?!
It comes out about 3 inch or so then stops, ive been trying for ages with no luck.
Any suggestions would be a great help
You are trying to extract it the right side yeah? It can only be removed from the dizzy side, and as said you usually have to spin it about 180 degrees to pass each bearing seat.
Orion_Gav
Sep 29, 2015 04:50 PM
