Inner wing rust...
Old May 15, 2006 | 06:08 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Default Inner wing rust...
Inside the rear arch on the fuel cap side, rust has been found
Whats involved in sorting this? is it a big job? huge extra bills at the bodyshop is all i need
Outer arch is fine btw, has been welded in the past
Old May 15, 2006 | 08:16 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
No-one?
Old May 15, 2006 | 08:30 PM
SafeChav's Avatar
SafeChav
So you mean the rust is only evident from inside the boot when the trim panels are removed?
Old May 15, 2006 | 08:32 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Yeah only seen since car has been fully stripped....
Old May 15, 2006 | 08:42 PM
SafeChav's Avatar
SafeChav
Well, as you've probably read enough times the only definate way to remove the rot is to have the whole panel off, not very easy on a rear quarter though
Its only single skin there, i expect there is a repair section that you can buy. Thats a very common place for them to rust. Can you get a picture of it?
hang on actually, the filler pipe doesnt enter the car? Is it the panel that is behind the filler neck (that isnt the outer bodywork though)
Old May 15, 2006 | 08:45 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Yeah the panel around the filler pipe, assumed it was inner wing...
can't see how you'd get to it to repair without serious chopping of panels inside or out
Old May 15, 2006 | 08:47 PM
SafeChav's Avatar
SafeChav
Can you get a picture, i can't fully remember what hatchbacks are like on the inside.
Old May 15, 2006 | 09:03 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Will be down at the bodyshop tomorrow so yeah i'll try get a pic
cheers
Old May 15, 2006 | 09:22 PM
SafeChav's Avatar
SafeChav
Ah so the bodyshop have just informed you of this bad boy then???
Old May 16, 2006 | 12:21 PM
Dan's Avatar
Dan
Fuckin wounder mate! Not sure how you'd go about repairing that! Might ask the old man if he's repaired one before if you like?
Old May 16, 2006 | 12:24 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
yup
Asked me if i wanted it done thought i'd get an idea of whats involved before i go ahead yet
Yeah cheers dan would be great , will get done one way or another just a fuckin setback for now
Old May 16, 2006 | 12:28 PM
Dan's Avatar
Dan
Yeah pisser mate!
I'll ask him tonight and catch you later, i'll be online tonight but not till later!
Old May 16, 2006 | 01:01 PM
SafeChav's Avatar
SafeChav
Wheres this picture then
Old May 16, 2006 | 01:18 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
When i finish work will be going down, thats if i've got my camera in the car
Old May 16, 2006 | 01:19 PM
SafeChav's Avatar
SafeChav
Old May 20, 2006 | 09:50 AM
R6Franky's Avatar
R6Franky
Mines rotten in the same place although the outer skin is perfect.
I started a resto on my car a month ago but when i saw this problem it deflated me and i haven't been in the garage since. What to do??
Old May 20, 2006 | 04:44 PM
Red16's Avatar
Red16
my rs1600i was the same as R6Franky's car, cut bits of plate and bent to shape then welded them in place, once tghe rusty pieces had been cut out of course. pics in my resto thread, on one of the pages
Old May 20, 2006 | 05:02 PM
Red16's Avatar
Red16
heres one of my rear arches after a clean up, mark on here where yours is rotten so we can see where you mean exactly.
lower rear inner arch rot
the lower front inner arch rot
rot nearly all cut out
the nearly finished article
cant find the pics of the underside after welding and plating, will have a good look later, see if they turn up
its not too big a job for a bodyshop to be honest, pop down to your local place and show them, see what you're looking at paying.
Old May 20, 2006 | 05:08 PM
gus's Avatar
gus
seeing that picture has just reminded me of something
note made
Old May 20, 2006 | 05:12 PM
Red16's Avatar
Red16
note made
enlighten us then...
you got an in car fuel cell by any chance?
Old May 20, 2006 | 05:15 PM
gus's Avatar
gus
busted
yes mate
just need some tabs welded on so i can bolt it to floor
Old May 20, 2006 | 05:24 PM
Red16's Avatar
Red16
cool
Old May 20, 2006 | 05:27 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Thanks for the pics, after a look its mostly filler pipe related
Haven't got any of this thank god or i think i'd of given up on it
But will show guys at the bodyshop these pics so they get an idea, bit of relief there mate thanks a lot
Old May 20, 2006 | 05:29 PM
gus's Avatar
gus
sorry post hijack dude
Old May 20, 2006 | 05:34 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Lol no worries
Old May 20, 2006 | 05:50 PM
Red16's Avatar
Red16
Ad4m RST no probs, hope you get it sorted ok
Old May 20, 2006 | 07:23 PM
Wazzzer's Avatar
Wazzzer
where the inner arch meets the boot floor? If its a yes I'm sorry to say it mate but when mine was like that it ended up being rotten chassis rails...
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Iain Mac
Sep 30, 2015 09:39 PM
