Mondeo Engine Problem???
Old May 15, 2006 | 05:30 PM
Phil DJ's Avatar
Phil DJ
Default Mondeo Engine Problem???
Me and a mate of mine have just replaced a head gasket on a Mondeo 2.0 litre Zetec engine.
Everything has been put back together correctly and torqued up properly but there still appears to be a problem with the spark from 2 of the plugs.
We've replaced the spark plugs, ignition leads and the coil pack and we've checked that all electrical plugs are plugged in correctly but the problem still persists.
Basically, it's not running properly and it's very difficult to get started. On further investigation, we found out there is a weak spark on plug 3 and plug 4 appears weaker still.
Anyone got any ideas what it may be???
All help much appreciated
Old May 16, 2006 | 06:30 AM
Phil DJ's Avatar
Phil DJ
Someone must have an idea???
Please
Old May 19, 2006 | 09:03 PM
magnum james's Avatar
magnum james
check the wiring for the coil pack has not melted on the egr pipe just below the coil bracket also the metal on the terminals sometimes opens up gving a poor connection (three pin connector on coil)also just make sure nothing trapped when head refitted or dowel in head not holding head up might be worth checking compression (poss burnt out valve?)
Old May 19, 2006 | 10:11 PM
SafeChav's Avatar
SafeChav
Did you change the coil pack for a known working one? Theres a common fault on the one plug, number 3 IIRC, if not its number 4......very coincidental....
Old May 20, 2006 | 08:28 AM
DazC's Avatar
DazC
That's strange!!
Plug 3 and plug 4 are connected to seperate coils! Plugs 1 and 4 are fired by the same coil so if 4 has a very weak spark, then 1 should be equally as weak! As with 2 and 3.
If you had said that it's not firing on 1 and 4 together, or 2 and 3 together, then it would be more logical that the coil pack or the wiring to trigger it was U/S.
Old May 20, 2006 | 09:33 AM
Phil DJ's Avatar
Phil DJ
Coil pack that we fitted is defiantely fine. Used to be on my old XR2i 1.8 16v. All wiring is fine as we checked that already.
I'll see about getting it pressure tested next then
Old May 20, 2006 | 09:36 AM
SafeChav's Avatar
SafeChav
Sounds silly but have you checked the plugs/leads?
Old May 20, 2006 | 09:48 AM
DazC's Avatar
DazC
Are the plugs and leads new? If not, then I wouldn't do much more without replacing them.
The Zetec leads are prone to breaking if disturbed.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
