Dump valve..
Old May 15, 2006 | 12:12 PM
RsDarren's Avatar
RsDarren
From: Dewsbury, The parts were they don't abduct their own children!
Default Dump valve..
When driving my sapph cossie and come to letting of the throttle the dump valve should be all I hear. But it isn't!!!
I get half a dump valve and half chatter
I've checked that everything is connected correctly, but it doesn't sound like it should do?
Any ideas what it could be??????
Old May 15, 2006 | 12:28 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
if the dump valve is on the cold side (passenger side) then you wont get any chatter, but if its on the normal place on top of the cooler then you`ll get dump then chatter thats what ive got
Old May 15, 2006 | 12:39 PM
R4N SS's Avatar
R4N SS
thats fine mate
Old May 15, 2006 | 12:55 PM
RsDarren's Avatar
RsDarren
It's between the cooler and the throttle.
Just wanted to know what people thought as you hear most cars have either dump vavles or chatter only? yet mine has a bit of both.
For piece of mind really.
Old May 15, 2006 | 01:53 PM
p_jay78's Avatar
p_jay78
mines both....and my old was was both....
twice the fun
Old May 15, 2006 | 04:08 PM
S2RSsteve's Avatar
S2RSsteve
I thought the dump valve could only go by the trottle bodies!
Learn something new every day
Great stuff
Old May 15, 2006 | 04:15 PM
p_jay78's Avatar
p_jay78
here's a question....will you get more chatter with a bigger air filter....like one of those Woodford Garage Group A jobs?
Old May 15, 2006 | 06:36 PM
cossiegreg's Avatar
cossiegreg
the dump valve is ment to be near the throttle
Old May 15, 2006 | 07:13 PM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
mine is on the cold side and chatters like an eskimo's balls with this air filter.
Old May 15, 2006 | 07:14 PM
Lo@der's Avatar
Lo@der
sorry thought it was a better pic
Old May 15, 2006 | 07:29 PM
S2RSsteve's Avatar
S2RSsteve
Mine sound like a flippin horse, Probably all them pony's stuck under the bonnet!!
Old May 15, 2006 | 07:42 PM
Lo@der's Avatar
Lo@der
i wish mine run on sugar lumps
Old May 15, 2006 | 09:40 PM
rinus_2005's Avatar
rinus_2005
I've noticed that too. Tough it's not so strange, the dv outlet has a diameter of 25mm? Ur intercooler is mostly 62mm? So you close the throttle, dv opens, but diameter is much smaller, thus creating pressure buildup, meanwhile there is no exhaustgas to propel the turbo. So your turbo will stall. Driving without a dv will obviously create even more lag.
A dv is nevertheless very usefull to minimise stalling
ofcourse ALS (antilagsystem) will sort stalling, but pretty expensive and won't last that long, so more rebuilds needed. But, gives some good bangs
i've heard about a guy who had 2 dv's installed, but i don't know if that really sorted the stalling
Old May 15, 2006 | 09:50 PM
rinus_2005's Avatar
rinus_2005
The chatter is already there, but the standard airbox dampens it. A nice cony item will let u hear much better. For max effect, a conefilter directly attached to your turbo
Old May 17, 2006 | 01:36 PM
TurboShed's Avatar
TurboShed
Cossiemodo
I use the broom handle mod, chatter all the way baybeeeeeeee!!!!!!
Old May 17, 2006 | 01:42 PM
rsnissan's Avatar
rsnissan
it doest matter what side its o, the reason you get half chatter and dump is the lift off pressure of the diaphram is not being reached so you get chatter (some are different to other and some are adjustable) and as soon as it is reached you get dump.
Old May 17, 2006 | 01:48 PM
p_jay78's Avatar
p_jay78
whats the broom handle mod?
Whats the advantages / disadvantages of attaching the filter directly to the turbo?
Old May 17, 2006 | 01:50 PM
boost mad's Avatar
boost mad
the spring in the dump valve could also be quite strong, thus not opening until the throttle is completly close
i had this with one of my dump valves, the bailey one i had b4 that had a weaker spring and didnt do it
nothing wrong with it at all
Old May 17, 2006 | 05:05 PM
DAN P's Avatar
DAN P
lol when i first got my cossie the d/v was broke leaking air so i put the brom stick in the whole and never put a d/v back on
cossie09
Oct 11, 2015 06:29 PM
DAZZER
Sep 30, 2015 08:43 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
