Cossie; chipped or not?
Old May 14, 2006 | 08:16 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Cossie; chipped or not?
I have bougth a sierra cosworth 4x4 which was sold to me as having a stage one chip. After changing the standard actuator for a -31 item I tried to adjust the boost.
What I noticed was that anything peaking above 17 PSI the ECU shut down everything. So now I have adjust it to peak at 16 PSI and holding 14,5 PSI and the limiter on the ECU doesn't come in.
But is this a standard chip as on my previous cosworth with standard chip it only could peak at 13,8 PSI most before the limiter came in. (held max was 11,6 PSI).
And if not how does the ECU know that the boost exceeds 16 PSI as it has a standard 2 Bar mapsensor (I think)?
Hope someone (Stu?) can help me with this.
YBJ
Old May 14, 2006 | 08:58 PM
DazC's Avatar
DazC
That sounds like a stage 1 chip to be honest....
Old May 14, 2006 | 09:47 PM
Jim Galbally's Avatar
Jim Galbally
sounds like a stage1 to me
Old May 15, 2006 | 09:48 AM
daz1968's Avatar
daz1968
I think standard map can read up to 18psi, but not 100% sure, but does sound like a stage 1 chip.
Old May 15, 2006 | 09:53 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Than I don't understand how the ECU can tell what the boostpressure is anything above 14,5 PSI??
Old May 16, 2006 | 08:00 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Or can you tell on the numbers on the chip if it is standard or not?
It is a cos 4x4 redtop engine from 1991.
Old May 16, 2006 | 08:08 AM
Stu @ M Developments's Avatar
PassionFords Creator
Are you sure you havent got an overboost pressure swicth in teh plenum or intake elbow area? Often has 2 wires going to it.
Old May 16, 2006 | 08:36 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Yes I am sure, because recently I have had that section of the engine when putting on some new engine mounts. And I didn't see anything special up there.
Old May 16, 2006 | 06:24 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Stu, do you have any other suggestions ? Does it sound like a standard chip to you?
Old May 16, 2006 | 06:45 PM
nellyscossy's Avatar
nellyscossy
hi
if the map sensor is half black/grey then its a 3 bar, all black is usually standard, ive never seen a standard chip boost to 18psi either..there are no bleed off pipes etc been fitted on the actuator/amal valve is there??
(i had that once and when i peaked at 18psi the car nearly put me through the windscreen!!!)
Old May 17, 2006 | 07:51 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Double checked everything yesterday and also no bleed pipes anywhere, just plane standard pipe work like it left Ford.
Will look at the mapsensor, I can remember a standard has a character with '3' in it and a 3 bar mapsensor not... Does any know the right numbers on it?
I ones had before a black 3 Bar mapsensor. The guy I got it from told me that it was very special as it was a motorsport item. Usely they are grey indeed.
Old May 18, 2006 | 08:20 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Old May 18, 2006 | 08:34 AM
richm's Avatar
richm
2-bar sensor part# APS02/03
3-bar sensor part# APS05
2bar standard sensor is specified to +16.8psi max at full scale output (4.75V)
Old May 18, 2006 | 09:59 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks richm, good answer . So a 2 Bar mapsensor can sense up to 1.15 Bar.
Next thing I need to now what the max boost for a standard chip is (where the limiter comes in) and with that I can see if it is stage one or not.
Old May 18, 2006 | 10:01 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
So is the early on mentioned 13.8 PSI indeed the limit for a standard chip?
Old May 18, 2006 | 01:32 PM
wightie's Avatar
wightie
any chip can measure up to the limits of the map sensor fitted (so long as its the correct map for the chip, simply plugging a 3bar onto a standard or stage 1 will not allow it read to 2 bar for example. it will be unable to interpret the signal it receives correctly).
as such a standard chip can measure up to 1bar above atmosphere (and -1bar vaccum hence the 2bar designation).
where the difference lies is in how the chip are mapped to deal with these readings.
a standard chip is set to run with boost of 0.7bar, about 10psi. anything above this is outwith its optimum range and it cannot adjust fueling to take advantage of this extra pressure up until 1bar limit where it will shut off....rather suddenly. its very possible to wind up your boost with a standard chip to the limit of 1bar, the chip can after all read it and the extra pressure certainly makes it feel quicker. the issue is that it will most certainly run lean and will also be less than optimum
using a stage 1 chip will adjust the settings so that boost can be increased to this 1bar ceiling AND the fueling etc is increased to deal with this. this results in more power and better performance since readings are all within an accepted range.
as such you cant use the boost reading on your car purely to gauge if its been chipped or not. a reading of 1bar, the max setting for stage 1, would be an indication that it was chipped however since the boost setting is a mechanical function and entirely independent theres many other factors that could be contributing instead, ranging from a fault or leak to simply a previous owner increasing boost with little regard for the car itself.
why dont you just take a look at the ecu. if its never been opened its safe to say its not chipped. if it has been why not open it up and look at the chip thats in there. it should quickly become apparent as to whats in there or not.
Old May 19, 2006 | 08:00 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
I have had the ECU out and indeed it has been opened by the previous owner. So what should a standard chip has voor charactars on it that I can refer to?
And the maximum boost it shut down is 16 PSI (1,1 Bar)
Old May 19, 2006 | 08:03 AM
GARETH T's Avatar
GARETH T
its easyer iif you take a photo of the inside
Old May 19, 2006 | 08:37 AM
richm's Avatar
richm
this is what a standard unmolested L8 looks like:
standard L3E31 red-top chip:
Old May 19, 2006 | 08:48 AM
GARETH T's Avatar
GARETH T
i dont think ive ever seen a standard chip
Old May 19, 2006 | 09:11 AM
richm's Avatar
richm
that's the ECU we used on the Zetec Gareth - I've never seen one with the cover seals intact before either! and we trashed it!
Old May 19, 2006 | 09:13 AM
GARETH T's Avatar
GARETH T
good work
Old May 19, 2006 | 09:18 AM
Dean Saff's Avatar
Dean Saff
tbh I wouldn't even risk it keep the boost down get it to a decent tuner and have it checked and setup properly.
you here to many horror stories about people messing with boost etc only to find they bugger the engine as a result
Old May 19, 2006 | 10:44 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
ok thanks guys, will check the numbers this evening and then post a picture of it!
Old May 20, 2006 | 10:02 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Here is a picture of my ECU:
As you can see, it says something different on this chip.
"COSW 4048 MA4" if I am correct.
Anyone any idea if this is a standard chip? This cossie was imported from Italy.
Old May 21, 2006 | 07:01 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Old May 23, 2006 | 10:44 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
up
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
