Engine failures??
Old May 14, 2006 | 07:52 AM
Alvyn's Avatar
Alvyn
Default Engine failures??
how many you had on your pride and joys! in 10+ yrs I've had 2 in the saff one at 70mph the other was down to too much silicone being used to put the sump on and blocking the p/up NOT BY ME I MAY ADD
other than the every day usual parts has been incident free motoring
Old May 14, 2006 | 01:45 PM
Alvyn's Avatar
Alvyn
no one else
Old May 14, 2006 | 01:58 PM
RS500/364's Avatar
RS500/364
i have had 5 rebuilds in 4 years
loads of ŁŁŁŁŁŁŁŁŁŁs
1 got nick with the car at national day 2004
1 only lastest 2K unchballs:
1 went on and on
1 in the RS500 just been mapped
another in being done now for the saff
Old May 14, 2006 | 02:00 PM
rscozzysie's Avatar
rscozzysie
Default Re: Engine failures??
i had the same problem when someone had ptu too much sealer on
Old May 14, 2006 | 03:01 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Done a valve or 4 in my mini head once
Old May 14, 2006 | 03:28 PM
Ian M's Avatar
Ian M
first engine= bolt sheared on alternator bracket belts came off and went in the cam belt.
second engine= complete 4+4 engine burnt a valve (too much boost)
third engine= rebuilt the 4+4 engine spun the shells after 75 miles (caused by lint off a rag collecting at the pick up pipe strainer)
fourth engine= rebuilt the 4+4 engine again melted three pistons after 1200 miles (caused by a shit greys chip with too much ignition advance)
fifth engine= rebuilt the 4+4 engine again block cracked after 5k miles
sixth engine= rebuilt again using a 205 block no problems at all and used up untill 2 1/2 years ago.
seventh engine= this is my current one.
this is in 11 1/2 years.
Old May 14, 2006 | 04:48 PM
CharlieSaff's Avatar
CharlieSaff
Shit Ian Some bad luck there chap
This is my second Cossie and I rebuilt the 205 block myself and then got Karl Norris to live map it, well impressed
Luckily I rebuilt it through choice (was a bit tired after 95,000 miles) and not because anything bad happened
Old May 14, 2006 | 04:55 PM
John Laverick's Avatar
John Laverick
I had a con-rod bolt snap at 70mph in my old RST...bought a second hand engine and its been spot on since
See the Rod/Piston in my avatar
Old May 14, 2006 | 05:11 PM
DAN P's Avatar
DAN P
spun a shell in my old cossie now rebuilding a new engine
Old May 14, 2006 | 05:18 PM
Rab's Avatar
Rab
Fucking superstar........
Completely mangled my first RST engine.
Snapped a rod in the second one (it was a ZVH)
And most recently melted 2 in the Fiesta after a fuel pump failure
New spec will be decent though
Old May 14, 2006 | 08:32 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The block has just cracked, first thing in 9 years of cossie powered cars.
Did have the engine rebuilt 3 years ago because it was tired.
Steve.
Old May 16, 2006 | 07:04 PM
Alvyn's Avatar
Alvyn
not that many people!
Ian you made up for a few though
3i Jim
Nov 20, 2015 05:12 AM
hopper350
Sep 4, 2015 12:53 AM
