check my t3
Old May 13, 2006 | 07:18 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
Default check my t3
whos tryed a home rebuild?, this has more movment thats a barrel full of horny eel's so ill save it from scrap and give it a rebuild see how it goes, its marked to be rebuild as balanced as poss
also wheres cheapest for a rebuild kit?
helpful comments from those who have attempted it are very welcome i knwo ppl who have rebuilt t25's and t2's at home with huge sucess but no body seems to try on a t3 due to easy 2nd hand availability
Old May 13, 2006 | 09:05 PM
turbo.jon's Avatar
turbo.jon
Nige Danny@RADesigns on here does them for £68 i think i had to take all housing off my turbo and have a stud drilled out as it bloody snapped it dont look that hard to rebuild it just getting the balence right which cant be done perfect at home but can give it a try might be lucky
Old May 13, 2006 | 09:15 PM
1.9 xr2 on 40's
st170 breaking
it shud line up ok to keep balance as best as poss
found kits for £40 so far
is it worth getting a stud drilled?, cant u just get another housing?, after all the hassle i'd just change it, take it u still aint usin teh fookin thing
and get on msn
Old May 13, 2006 | 09:26 PM
Zetecfiesta's Avatar
Zetecfiesta
ha you should see mine its fcuked!!!!
Old May 14, 2006 | 12:42 PM
GrimmeRS2K's Avatar
GrimmeRS2K
need to get them balanced properly really, i was gonna attempt to do mine, but was told not to bother as a unblanced turbo wont last long mate.
Old May 14, 2006 | 12:59 PM
SafeChav's Avatar
SafeChav
You need to check the backplate of the compressor housing isn't worn, the oil seal sits in a hole in it, but if the shaft is wobbling its more than likely the backplate is worn (alloy) so that too will need replacing.
Also the cheap kits won't do you, as you have a 360 thrust, AND you need to check your shaft for signs of scoring.........if its scored u will need the shaft machining (if its not worn toooo bad) and oversize bearings....
Old May 14, 2006 | 06:07 PM
turbo.jon's Avatar
turbo.jon
Originally Posted by 1.9 xr2 on 40's
is it worth getting a stud drilled?, cant u just get another housing?, after all the hassle i'd just change it, take it u still aint usin the fookin thing
and get on msn
its a .48 housing and i tried to get hold of a new 1 but didnt come up with any so had it drilled out worked though hopefully bloody thing should be back on road in next few weeks then i got mot it next month
Old May 14, 2006 | 06:58 PM
1.9 xr2 on 40's
st170 breaking
cant have done 1k since the last 1
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
