Help Needed. I Have a Misfire!
Old May 13, 2006 | 05:39 PM
kez_cos's Avatar
kez_cos
Default Help Needed. I Have a Misfire!
Any idea of what would cause an intermittent misfire in my cossie?
1st happened at pod, at high rev's full boost.
Now occasionally happeneing at low rev's with no boost. Today was at about 3 thousand. Rev counter flew up to 7 thousand but the engine rev's did not rise, scared every bird in my village with an almighty bang!
Starting to get really, really annoying now as it does not follow any pattern, does it anytime which is most inconvenient when playing with a Z4!!!!
Any advice would be much appreciated!!!
Old May 13, 2006 | 05:40 PM
MAD EVO 4's Avatar
MAD EVO 4
I would of thought Martin being a tech he would of sorted this for you
Old May 13, 2006 | 05:44 PM
kez_cos's Avatar
kez_cos
Because he was fixing his diesel saff and will be tomorrow. He is a busy boy!!! So thought i would see if anyone on here has any ideas!!!
Old May 13, 2006 | 05:48 PM
MAD EVO 4's Avatar
MAD EVO 4
This is very true.
Im sure the good people on here will be able to help you out.
Old May 13, 2006 | 05:50 PM
kez_cos's Avatar
kez_cos
Fingers Crossed!!!!!
Old May 13, 2006 | 06:40 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
give me a chance.. i've got my own headaches to sort!
Old May 13, 2006 | 06:43 PM
Rs1's Avatar
Rs1
Crank position sensor??
Old May 13, 2006 | 06:49 PM
Turbo Zetec
Engine Machinist
its not the plugs or map sensor btw... tried those
am hopefully going to try coolant temp sensor and air temp sensor tomorrow if i get time.
Old May 14, 2006 | 09:40 AM
kez_cos's Avatar
kez_cos
Anyone else got any ideas?!?!?!
Old May 14, 2006 | 09:43 AM
GARETH T's Avatar
GARETH T
leads,,, phase/crank sensor and wiring
Old May 14, 2006 | 10:01 AM
melzieann's Avatar
melzieann
Have you still got the 3 connecter plugs at the back of the engine bay?
Old May 14, 2006 | 10:06 AM
kez_cos's Avatar
kez_cos
Yes connector plugs still thee!
Old May 14, 2006 | 10:12 AM
bud-weis's Avatar
bud-weis
Football Cwazy
cut them out and re-solder the wires then
Old May 14, 2006 | 10:18 AM
melzieann's Avatar
melzieann
I had exactly the same problem, try cleaning them out but DONT put anything in them ie wd40 make sure inside the connector is clean and dry, if that dont fix it,
time to cut them out and hard wire them
Old May 14, 2006 | 10:20 AM
kez_cos's Avatar
kez_cos
Thanks guys, will try cleaning them now. Fingers crossed!!
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
