help please>>
Old May 13, 2006 | 04:59 PM
davsmith64's Avatar
davsmith64
Default help please>>
ok i'm just wondering if anyone knows how a rst will run with a fooked map sensor??
as i have a problem with mine i think but the car runs totally like a bag of poo at the mo.. (missing and smoke from the rear)
could this be anything to do with the map sensor as its adjusting the fuel..??
Old May 13, 2006 | 05:03 PM
Oranoco's Avatar
Oranoco
Wouldn't have thought so. When the MAP sensors go down in a RST ECU they tend to just pink their tits off when they come on boost.
Old May 13, 2006 | 05:24 PM
biglee's Avatar
biglee
Audio specialist
when mine did that it was the cold start injector on all the time.....if yours is plugged in... un plug it and see if its any better...... took 2 mins for mine to clear up..... turned out to be stuck on....oppps
Old May 14, 2006 | 03:49 PM
SafeChav's Avatar
SafeChav
When you say stuck on......do you mean held on permenantly electronically? Or fucked?
