anyone know of a good strong double sided tape ??
Old May 13, 2006 | 12:32 PM
jaiscossie's Avatar
jaiscossie
Default anyone know of a good strong double sided tape ??
what is the best type of tape for fixing on the green side bump strips on a fiesta rs turbo? i brought some 25mm wide stuff on a roll from local paint suppliers and they have only been on there a month and with the sun they are starting to peel back. does anyone know of a good strong tape? or something else i could use. thanks
Old May 13, 2006 | 12:34 PM
Damo V's Avatar
Damo V
3M tape from Brown Brothers or the like
Old May 13, 2006 | 12:35 PM
Damo V's Avatar
Damo V
But if your side strips were damaged (stretched) when they were removed, then they will never stay on properly (unless you use a strong adhesive)
Old May 13, 2006 | 12:36 PM
jaiscossie's Avatar
jaiscossie
is it the stuff with the green backing you peel off?
just seen this what do you think to that?
http://cgi.ebay.co.uk/DOUBLE-SIDED-C...QQcmdZViewItem
ill try brown brothers now m8 thx
Old May 13, 2006 | 12:37 PM
Damo V's Avatar
Damo V
No thats shit, got to be 3M, comes in a plastic case with 3M all over it about 20 quid for a roll which is 8 mm wide
Old May 13, 2006 | 12:40 PM
jaiscossie's Avatar
jaiscossie
do you have a web addy mate for the tape? needs to be 25mm wide as the mouldings are about 30mm
Old May 13, 2006 | 12:47 PM
Damo V's Avatar
Damo V
so put three rows of 8mm
Besides they do make wider.... 8mm was an example
Old May 13, 2006 | 12:48 PM
jaiscossie's Avatar
jaiscossie
they are the old ones going back on as cant get new ones anywhere . would you suggest using something else other than a tape then? they did get slightly kinked but not to bad
Old May 13, 2006 | 12:54 PM
Damo V's Avatar
Damo V
http://solutions.3m.com/wps/portal/!ut/p/kcxml/04_Sj9SPykssy0xPLMnMz0vM0Q9KzYt3d9KP0I8yizeIN_K31C _IcFQEAF2WFVI!?PC_7_0_BBL_root=K3BHNB8005gv&PC_7_0 _BBL_output=html&PC_7_0_BBL_gvel=50W71J5H7Vgl&PC_7 _0_BBL_vroot=CB1HCVHLJMge&PC_7_0_BBL_node=ZK8DVLMZ WJbe&PC_7_0_BBL_theme=aad_portal&PC_7_0_BBL_comman d=AbcPageHandler
Old May 13, 2006 | 12:56 PM
Damo V's Avatar
Damo V
Old May 13, 2006 | 12:57 PM
Damo V's Avatar
Damo V
http://solutions.3m.com/wps/portal/!ut/p/kcxml/04_Sj9SPykssy0xPLMnMz0vM0Q9KzYt3d9KP0I8yizeIN_K31C _IcFQEAF2WFVI!?PC_7_0_BBL_root=K3BHNB8005gv&PC_7_0 _BBL_output=html&PC_7_0_BBL_gvel=50W71J5H7Vgl&PC_7 _0_BBL_vroot=CB1HCVHLJMge&PC_7_0_BBL_node=Z3ZCQZJG 37be&PC_7_0_BBL_theme=aad_portal&PC_7_0_BBL_comman d=AbcPageHandler
Old May 13, 2006 | 12:59 PM
jaiscossie's Avatar
jaiscossie
thanks mate ill go have a look now
Old May 13, 2006 | 01:00 PM
Damo V's Avatar
Damo V
Product Catalogue for Automotive Aftermarket 3M™ Adhesives 3M™ Auto Adhesive Tapes
3M™ Acrylic Foam Tape
[click to enlarge] A versatile, double sided foam tape for critical fixing applications, and made from high density acrylic foam. Supplied as rolls in 0.8mm and 1.1mm thicknesses and a choice of 6 widths from 6mm to 50mm.
Part No: Description Size Items/Unit
80318 Black, 2 rolls per pack 1.1mm x 6mm x 40m 12
80319 Black 1 roll per pack 1.1mm x 9mm x 20m 12
80320 Black 1 roll per pack 1.1mm x 12mm x 20m 12
80322 Black 1 roll per pack 1.1mm x 19mm x 20m 12
80323 Black 1 roll per pack 1.1mm x 25mm x 20m 12
Additional Information
Offering high adhesive strength, 3M™ Acrylic Foam Tape is OEM specified and suited to applications with a high adhesive requirement such as body side mouldings, badges and bumper trims. Combines high conformability, high peel strength, elasticity and internal strength.
Old May 13, 2006 | 01:01 PM
Damo V's Avatar
Damo V
links wont work, but find bodyshop supplies adhesive tapes etc
Old May 13, 2006 | 01:03 PM
jaiscossie's Avatar
jaiscossie
thanks mate your a star. would you say the 0.8mm thickness would be the one to go for ? or would the 1.1mm be stronger?
Old May 13, 2006 | 01:05 PM
Damo V's Avatar
Damo V
You want 25 mm width dont you?
Old May 13, 2006 | 01:07 PM
Damo V's Avatar
Damo V
As I say though if trims are badly kinked, you gonna struggle to make it look nice whatever you use
You coould try warming them up in an oven on a flat surface or something, see if they reshape
Old May 13, 2006 | 01:08 PM
jaiscossie's Avatar
jaiscossie
yes but it says they do two thicknesses further up. 0.8mm or 1.1mm
Old May 13, 2006 | 01:09 PM
jaiscossie's Avatar
jaiscossie
i wouldnt say there badly kinked as were very carfully removed. its mainly on the ends where they are starting to lift up
Damo V's Avatar
Damo V
1.1 will take up irregularities a little better
Old May 13, 2006 | 01:11 PM
Damo V's Avatar
Damo V
You will need to clean everything thoroughly with a wipe first before fitment too, BBrothers will selll you this also
Old May 13, 2006 | 01:20 PM
jaiscossie's Avatar
jaiscossie
what is that called ? like a panel wipe?
Old May 13, 2006 | 01:21 PM
Damo V's Avatar
Damo V
yeah that should do
Old May 13, 2006 | 01:22 PM
jaiscossie's Avatar
jaiscossie
Old May 13, 2006 | 01:23 PM
graham c's Avatar
graham c
use stickerflex wont come off again
Old May 13, 2006 | 01:26 PM
500NEIL's Avatar
500NEIL
it makes a big difference if you warm the glue on the tape up a bit with the heat gun then stick it staight on
markk
Dec 2, 2021 06:59 PM
borboyous
Aug 22, 2015 11:17 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
