Bleeding brakes- pt 2 :wall: (urgent)
Ok then, i've strated bleeding the brakes, there are no leaks, BUT the fluid seems to just trickle of the bleeding kit, rather than flow out smoothly- there are 2 bolts on the top of my 4 pots, ones 11mm, and the other 6mm, am i right in assuming that i leave the 11mm one alone, and nice and tight, and just undo the 6mm a coupleof turns???
HELP me please!!!!!!!
rich, ive got an ezibleed here if you want it
i know that my normal bleed nipples are 11mm
doubt that helps you at all
worth giving willwood a bell for a quick answer?
