valve stem seals please help
hi i think my valve stems seals have gone on my FRST, its blue smoke from cold and when ticking over, but not when im driving it.
so its not the turbo or it would smoke when boosting (am i correct)
i have seen these on ebay
http://cgi.ebay.co.uk/FORD-CVH-TOP-H...QQcmdZViewItem
im thinking of attempting the job myself can any1 give me any tips.
Thanks in advance
Matt
Thanks in advance
Matt
mate, do yourself a favour and buy some proper made valve stem seals. yes buy pukker payen ones but dont buy cheap or "sugested" equivelent ones. there are even better ones than payen but ive used payen and they been fitted for years now with no probs. if fitted cheap ones that have lasted 3 weeks. had to do them again after this as they where as bad if not worse than before. just my opinion. id never use ebay as a source of engine components. theres no comback at all for starters
easy job to do as long as the valve comes up as they do tend to get stuck but make sure you block and cover the area your working on the head(oil gallerys) as you dont want to drop a collet then you will be buggered as i done this and took the head off and still could'nt find it and evently found it in the sump
