help
Old May 11, 2006 | 10:42 AM
Robs Frst's Avatar
Robs Frst
Default help
i have a xr2i 1.6 8v bought it 3 weks ago does any1 know where i can get smoked rear lights. also 1 of my spotlights stoped working does any 1 know how to change it. also im debating whether to get a mongoose or ashley competition exhaust which is the best 2 go 4. fanks
Old May 11, 2006 | 12:00 PM
rodney's Avatar
rodney
easy fella , you may be ably to get the rear lights from fiesta center in norwich but dont hold me to that , spot lights are easy to do thee are a few screws holding the spots in n each side if you undo these from the front they will come out and give you access to the bulbs ,
as for exhuasts mongoose is far better than ashley as ashley do sound nice but are a real crap fit , hope this heps mate ,
also im breakin a black 16v 2i if you need any bits and im not far from you as you prob know
Old May 11, 2006 | 12:21 PM
Robs Frst's Avatar
Robs Frst
Default 2i
im deffinetly interested in the 2i has it got any alloys and lowered suspension 2 b honest i need help with my car i felt ashamed to bring my car to ace cafe it needs wrk even tho there no rust everthing wrks except spotlights where u based
Old May 11, 2006 | 04:25 PM
Oranoco's Avatar
Oranoco
Spotlight is an easy one. As you look at the rectangular spot/fog cluster the outer ring has 4 evenly spaced holes (the other 4 are for the angle adjustment of the lamps). Undo these with a suitable allen key and the units drop out of the bumper. Pop the rubber cover off and use a test meter to check their is power getting to the lamp. If there is it's pretty sure the bulb has died so just pop a new one in and reassemble the unit as Mr Haynes would say "Refitting is the reverse of removal"
