remap or 195 chip for fiesta rs turbo
Hi people well my car will be ready next month i own richard xr2i1800 old fiesta rs turbo the red one j660cfu and its had a full restoration job evrything uprated on the engine s2 rs turbo owned it before me. my question is what do i go for a 195chip, or a remap if so where would you recomend in stoke on trent to go to there's either collins, castle performance or turbo systems,
Hi mate to be honest if you can give us a much better description on the spec then we'll able to help you out more
You'll only need a 195 chip or well in most cases if your running Beige injectors. Thats whats the 195 chip as been programmed for
If your running bigger inejectors (Begie's or even something else if you've got mad power) bigger turbo (possibly a t3 even a hybrid) cam, low-comp pistons basically the full works then it'll be best to get a remapped chip for you mods to run it to its true potential or even a live map to top it of but that anint cheap.
You can even run a 195 chip but wont be really making full use of your mods.
Like i said give us all an idea on your spec and we'll be able to help out
remap or chip
Hi sorry this is the spec:
mahle low comp pistons
arp big end bolts
full engine rebuild
all new big ends and mains bearings new mahle piston rings.
new uprated oil pump and new pick up pipe.
stage 1 organic clutch techni clutch
stage 2 head
kent cvh35cam
stage 2 t3 hybrid with bigger impaler and 47 housing.
collins actuator
cossie spark plugs
felpro headgasket
low temp thermostat
escort cossie fuel pump
ahmed bayjoo chip
everything is basiclly new on the engine all new gaskets core plugs seals
new water pump and cam belt and tensioner.
so what do you think i think that i will need beige injectors and a remap.
arp big end bolts
full engine rebuild
stage 2 head
kent cvh35cam
collins actuator
cossie spark plugs
felpro headgasket
low temp thermostat
ahmed bayjoo chip
paceo
03-02-2016 10:31 AM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
