5th injector
Old May 11, 2006 | 01:56 AM
gambit's Avatar
gambit
Default 5th injector
what are your views on a 5th injector is it a must have to get the best out of an mfi setup???? has any1 got any pics of their 5th injector setup please??? i want to run between 220-240 bhp on the ke unit
Old May 11, 2006 | 09:54 AM
Ezzy Danny's Avatar
Ezzy Danny
Im running simualer power and i have just bought a 5th injector system. Admittedly its not the best option but on MFI setup it probably is. Iv just had my pipe machined to fit the injector but i need the right pipe work for fuel and im not sure what ends i need anyone else any info?
Old May 11, 2006 | 11:54 AM
Sheldy's Avatar
Sheldy
What about this as an option?
No experience of them myself but sounds like a cost effective solution.
http://www.motorsport-developments.c...hinjectors.htm
Old May 11, 2006 | 04:40 PM
Oranoco's Avatar
Oranoco
A lot of people don't like them but I use one and it's helped me along to 248bhp and a top speed of 149mph. Even if it is a little crude
Old May 11, 2006 | 11:13 PM
gambit's Avatar
gambit
Default 5th
thanks for your replys chaps, any1 else got any opinions on this matter or pictures????
Old May 11, 2006 | 11:16 PM
PeterD's Avatar
PeterD
Gambit, heres the only piccy of my engine on the pc, 5th injector is there on the charge carrier (obviously )
Old May 11, 2006 | 11:23 PM
gambit's Avatar
gambit
Default 5th
who modified your charge carrier??? fusion fabrications??? thanks for the pic, do you think it is worth having a 5th injector and how does the injector connect to the metering unit??? is the standard fuel pump fine???
thanks
Old May 11, 2006 | 11:24 PM
T28 RST's Avatar
T28 RST
Ok then
Im not using one on mine and im in your 220 - 240bhp bracket
Old May 11, 2006 | 11:30 PM
PeterD's Avatar
PeterD
When i bought mines it came with the 5th injector that andy got fitted when he owned it, it uses the cold start injector line of the AFM leaving that disconected.
in all honesty i havnt driven an RST without one so im not the best to advise on the matey but as T28's car shows its not a necessity (very nice by the way you taking it to showcase on the 28th mate? )
Also im popping through to AVA next month for a rollers session to get the car whupping ass (even more )
Pete
Old May 11, 2006 | 11:39 PM
T28 RST's Avatar
T28 RST
Ok then
Yes i will be there coz its 5 mins from my house
Old May 11, 2006 | 11:41 PM
PeterD's Avatar
PeterD
Good stuff, i couple of guys from through here are getting a convoy together (hopefully )
Im bringing my S1 woohoo
Ill come over for a chat when i spot you
Old May 11, 2006 | 11:46 PM
T28 RST's Avatar
T28 RST
Ok then
Look forward to it
Old May 12, 2006 | 09:20 AM
Little_Hoss's Avatar
Little_Hoss
has any used the msd kit?
seems very reasonably priced and i mite be interested
Old May 12, 2006 | 09:27 AM
DanRSturbo's Avatar
DanRSturbo
Andy RST made 227 horse's without need for a 5th injector
Old May 12, 2006 | 10:07 AM
Ezzy Danny's Avatar
Ezzy Danny
I have a 5th injector sat there now and still unsure on how to fit it, what do i actually need to do with the cold start injector? i really im stumped with this now
Old May 12, 2006 | 10:39 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mine was still on 4-injector KE at over 250bhp!!
It varies SO much from car-to-car. The metering heads are, by now, so old and their performance is the governing factor as to how much power the car will produce on it without assistance.
With that said, the car can be mapped for more power and better off-boost economy with an additional mappable injector, so that is the nicer solution. Normally, on KE, there isn't a really nice way of increasing on-boost fuelling without ruining off-boost economy.
How about this.....??
Old May 12, 2006 | 11:07 AM
Rick's Avatar
Rick
Christian has summed it up. It makes me laugh so much when people go on about big power and no 5th. What is your crusie AFR??
C - those inkectors really should be angled.
Old May 12, 2006 | 11:39 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
6 injectors !!!
Old May 12, 2006 | 11:48 AM
Rick's Avatar
Rick
MF2 can run 4 injectors. I have one grey injector, and it's flat out....
Old May 12, 2006 | 11:49 AM
Little_Hoss
how much for that setup then?
Old May 12, 2006 | 11:50 AM
Little_Hoss
Christian and Beccy how much for this set up?
Old May 12, 2006 | 11:59 AM
Christian and Beccy
#1 in Spelling Club
That set-up worked well on a car that was 250bhp on a Stage 3 T3.
Rick - How fast does the boosted air travel along that pipe? My guessing starts at Mach 1.0.
It cost over £500 to build and covered no more than 1000 miles, I am open to offers on it (PM me).
It has both connectors on the pipes for the 2 803 injectors and a Banjo fitting on the other end for the metering head. The pipework is steel braided.
Old May 12, 2006 | 12:15 PM
Little_Hoss
pm sent
Old May 12, 2006 | 11:28 PM
gambit's Avatar
gambit
so this system is mappable but can be used in conjunction with the standard ke unit and ecu????
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
