goodridge fuel hose and finisher on fueltank
Can someone tell me which thickt fuel hose (goodridge) I need to connect my fueltank to my aeroquip (044) fuelpump connector (gold colored one, see the pic below)..
https://www.burtonpower.com/dets_pro...=80003&PSet=98
I have now idea which hose and connector I need, any help appreciated
thanks lambchops.. I'll wait for your answer..
I do know that I need a -10 goodridge connector now..
allthough it sounds stupid: how do I connect the goodridge connector to the braided fuel hose/line? and to the aeroquip connector?
Try contacting this guy on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8025046768
He used to have an ebay shop but it seems to have gone now.. It could be hes stopped selling but worth asking as he was very cheap.
Hope that helps
Hope that helps
are you trying to use the original pipe from the tank or do you want to use a -10 adaptor and a -10 fitting and hose?
the goodridge connectors are a swivel cutting thread. you screw the braided hose in the the collar then the fitting in to the collar and it cuts in to the pipe and seals. High pressure pipe sould be tested.
if you do I'll pm you a price for -10 adaptor and hose when i get in the office later.
cheers
Daniel
cheers
Daniel
JK12
33
Apr 26, 2021 12:09 PM
