Water temp sensor were and hose size UPDATED
Won thishttp://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
and has to sensors for water temp and oil tep were the best place to put the sensors
the water one what size is the hose centre were it needs to go so i can get the adaptor thanks
my oil temp is in the sump and the water temp is in the thermostat housing as you can see.
the thread size is 1/8 NPT IIRC but will have to double check when i get home.
if you didnt want to tap anything for the sensors you can get a t peice with the adaptor for a water hose and a sump plug with a threaded hole for the sensor.
I believe Burtons do both of these
Found this
http://cgi.ebay.co.uk/Raid-Hp-3-4-AF...QQcmdZViewItem
will this be ok or wil it put the filter out to much ?
what size are the water hose adaptor that is needed ?
JK12
33
Apr 26, 2021 12:09 PM
