Cosworth Turbo and oil pressure quesion ???
Old May 9, 2006 | 04:19 PM
EscortCosworthUSA's Avatar
EscortCosworthUSA
Default Cosworth Turbo and oil pressure quesion ???
I have a -6 AN fitting on my oil inlet on the normal T34 turbo (esccos) - but I am reading that with too high of oil pressure, it's not so healthy for the turbo seals. I also see on ebay (I know - not the best information site) that there should be a restrictor on the oil inlet to so-called lower the oil pressure to the turbo.
What do the experts think? -6 too big or fine and don't worry about it?
cheers!
Old May 9, 2006 | 05:19 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
yes it is restrict it to the same id as the standard fitting
Old May 9, 2006 | 05:30 PM
markk's Avatar
markk
way too big pal, it will flood the bearinghousing completely and will bypass the rings, the restrictor should be approx 3mm, mine is less due to a full flow bearing housing.
Old May 9, 2006 | 05:53 PM
EscortCosworthUSA
Yikes - I guess I'll get right on that and get it restricted - so about 1/8" or 3 mm then
Thanks for the help!
Old May 9, 2006 | 06:26 PM
markk's Avatar
markk
yes that wil be ok
Old May 9, 2006 | 06:52 PM
Tony Ryan's Avatar
Tony Ryan
Ironic then that the Ford GpA 909 fitting and pipe is in Dash 6 !
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
