SECS s8 and RP Lab
Hi
1. Is the SECS S8 ecu available new and in production?
Any info available? (Website seems to be down)
2. Does anybody have experience with the RP Lab for the Marelli?
I like the idea of plug and play, and/or using the the stock hardware.
Hope someone can answer
Regards
ESV
Regards
ESV
The RP Lab software / hardware will be launched to the UK market within the next few weeks....
Just so people know, this basically allows anyone with a lap-top (and the relevant software / hardware upgrades) to live map L8. It can also be converted to dizzyless AND ALS operation at an additional cost, should the customer so wish
Watch this space
.Watch this space
Originally Posted by jon@work
unless you want it to drive a Pectel monitor
Oh the irony of it, its developed off of the back of cracking the original software and then made less useful to those with a pectel by being protected against anyone doing it back to them
.But thats just a case of finding a tuner who will not use that option at your request i guess.
Someone buying it as a toy to experiment with can still do so
PassionFords Creator
.I envisage a lot of people would want to:
Buy the kit
Have it mapped initially by "a pro"
Be able to fine tune it as things change on their engine
Obviously if the "pro" in question locks the map, that means that those people cant ever edit it themselves, and also couldnt take it to any other tuner for adjustments, they would have no choice but to go back to the person who mapped it initially.
Im sure that suits the tuners just fine though, and people buying the ECU's have the choice of using a tuner or not based on if they will lock the map or not anyway.
So i wasnt being negative, just pointing out both sides of it.
) the original software but its protected against other people returning the favour.I would do EXACTLY the same if I had developed it, so again i wasnt having a go at it.
Originally Posted by esv
Hi
Regards
ESV
Regards
ESV
Err, ok
Although i meant if you currently have a pectel setup, this ecu mod is less useful to you as it means you cant use your pectel anymore.
Buy the kit
you don't necessarily need a pectel monitor though, if all parameters can be read by laptop / car pc or whatever (including scoping and datalogging and displaying on a virtual dashboard)
if there is enough demand, a separate 'pectel style display' can be produced and sold for a comparable price. it could include datalogging and / or other external inputs depending on what the customer wants and how much they want to pay.
one of the reasons why the datastream from the RP Labs converted ECU is not compatible with pectel monitors is because the datastream is much faster and contains more information. a display for the ICP datastream could also be compatible with pectel.
Who wants shonky old pectel when you cna have that instead? LOL
Links for those pics would be better Nick.
http://rplab.co.yu/Downloads/ICP_Too...orth_shots.zip
chip-3door
thank you matey, but i am not the full brains behind the project only the one that found it amongst all the other delights on the 'net and saw the potential and have helped to apply it to a shonky old ford
Yep, without Nick & Stu Sharpin, this would not have come to light
Would only have taken someone into 'Grales and cossies and it would have found its way to the ford world anyway probably sooner or later though, things this fantastic are hard to keep hidden
Just might have taken a few more years
Originally Posted by DogSmoke
If I bought one from a tuner and he'd locked it and I then wanted to go elsewhere and he refused to unlock it, I'd do him under anti-competition laws
If you buy windows microsoft dont post you the source code too
if you wanted to take it to a different tuner to have it mapped, you would just have to take it to your original tuner first who would remove the map that you paid them for and leave it unlocked for the next tuner. the original tuner could keep a copy of your map on file if you wanted to go back to it. it's just like the pectel t6 in that respect.
imo this is safer for tuners than eproms that can easily be copied (or the protection on them reverse engineered), as the password encryption is a one way process that not even the genius behind it all can get around to extract the maps. he can however wipe it completely clean to start again if somebody cocks up along the line.
that is a feature that does not benefit the diy 'tuner' but does the pro's. and it's a fair system imo as you cannot expect a tuner to do you a map on, for example a yb with t34, -31 and greys etc, that you can just copy for your mate who also builds the same spec motor.
Please accept your
with honours
(now awaiting witty comeback
Yep, i can certainly understand the logic of why someone like Stu would want to stop people being able to effectively have one of his "chips" for free.
Please accept your
with honours
)no, for not opening up the interfaces to it enough, not the complete source
Not the complete source, no, but you know what I mean.
If you buy one and then you want something doing and are FORCED to take it to that one tuner and spend your money with him then IMO it does breach competition rules.
you're arguing about something that is not there in reality
As I started this topic, thanks a lot for all the answers!!
I wonder, will the RP Lab be available only to pro tuners?
Will a diy-tuner also be offered to buy it?
No one know anything about the SECS S8?
regards
ESV
regards
ESV
ESV
The RPLab one will be available to be bought by anyone, (via Mike Rainbird if you are in the uk)
SECS ECU's are probably best sourced secondhand at the moment, like from RS500/104 up above
The RPLab one is only for L8 AFAIK, so if you have any other ecu you will need to upgrade to an L8 first.
