Easiest way to make 52mm holes for gauges?
a hole cutter is a clyinder with teeth at one end. and it has a drill bit comming through the middle.
http://www.tooled-up.com/Product.asp...l-Holesaw-51mm
im sure u will be able to find one that is 52mm
Better off using a hole punch. Gives a much cleaner and more accurate hole than those hole-saws.
http://www.frost.co.uk/item_Detail.asp?productID=8471
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
