abs belts/modulator question with pic
how the fook do the belts come off?
ive slackened off the bolt and it says to 'move' the modulator. WTF? its not moving at all and the belts are not 'slipping' off anything.
take the covers off, undo the 13mm that allows the top pully to move in then pop it off the pulley, the big end goes round the shaft, you have to remove a built up shaft from the box or hub or the shaft from the cv to get em off, or cut em if u dont need em
i need them so i can't cut them, i would have done that already otherwise lol
the cover is off and i have slackened off the 16mm(?) nut which pertrudes about an inch outwards next to the pulley.
il see if i can get pics, may help explain it a bit...
green arrow shows the bolt slackened off.
nothing is moving, there is a bolt hidden behind the oil filter (just shown in the picture) do i need to undo this also?
that aint the bolt u need to slacken off u need to take the 13mm one complteley out then it will twist enough to get the belt off
the one u say behind the filter is the one u need to remove!
its run out of MOT about a month ago anyway lol
the ABS is gonna go back on as it came off, until i can afford to sort the brakes properley.
thanks for your help people, both the belts are off now
dave_y: christ its all fun and games with you enit
you love it lol
cuttin bolts off.........ABS, what next
Just remove that ABS its fucking shite anyway
You ask anyone on here who has removed ABS and i bet you not one person says they regret it
you love it lol
Originally Posted by adamS2RST
what? you removed the abs and are not re-fitting it?
what? you removed the abs and are noW re-fitting it?
- it was a TYPO!
- it was a TYPO!
I'm not convinced sheriff
T is no-where near W
yeah its gonna stay on until i remove it properley, not just cutting the belts etc.
check out my new thread
Mad for it
- it was a TYPO!
- it was a TYPO!
Just admit you're either a spaz or wrong and i'll let it roll
- it was a TYPO!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
chris m1
Sep 7, 2015 08:02 PM
