Alright Chaps? I'm going to buy a new alloy rad and front mount for my s2 rs turbo and would like to know which is the best to go for. There are quite a few manufacturers out there and before I spend a fair bit of money I would like to know a bit more about it. Any advice would be great.
I have a GRS EVO 4 fitted and have no probs with it,running 18 psi and never see more than 10C over ambient after 20 minute sessions on track at Donno in August!!! Regards Micky
Can't decide between radtec and grs. Probably end up going for grs. Just wanted to know if it's necessary to have two fans for cooling or is one enough.
My car is an 89 spec. I will go for a standard new rad with GRS Evo 5 intercooler and twin kenlowe fans. What you think? If it's ok then I will order the intercooler and fans tomorrow.
will work a treat matey....
i got GRS evo 4 and standard new rad and i run 18psi and its sweet as a nut!
