Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Zetec More Power Needed
Old May 8, 2006 | 01:01 PM
escort cab's Avatar
escort cab
Default Zetec More Power Needed
I have a 1995 Escort cab 1800cc 130PS and was wondering what and can do do and how much it will cost to get some more power hopefully 170BHP+
Many Thanks
Jon
Old May 8, 2006 | 01:39 PM
JohnT's Avatar
JohnT
Only real way to get that much power is using weber alpha throttle bodies or twin carbs, with 285 profile cams (piper)!
Im using 45mm bodies (Ł1700ish) and Piper 285 cams (Ł300ish) with stage one head (Ł???). I rolling roaded my 1.8 with this set up and got 182bhp and 143lbft, But it costs!
Old May 10, 2006 | 07:11 AM
Paddy's Avatar
Paddy
Legend
Or lower CR, some machine work on the block, new management and slap on a turbo
Old May 15, 2006 | 12:13 PM
Wolfman83's Avatar
Wolfman83
Hi Im wondering how much effect a piper kam-set will have on a 96 zetec 1.8 130HP?
Isnt this one of the cheapest expensive ways to get more horsepower?
Old Jun 3, 2006 | 01:38 PM
s2turbo's Avatar
s2turbo
Default zetec
the 130ps zetec engine has been already extensively worked by ford. some people will disagree but its the truth. for pounds per horsepower its going to head towards the negative end of the scale, many people choose to switch to a 2l lump as its easier to get power from.
if you did decide to stick to the 1.8 you could do the basics such as a four branch manifold, full stainless system and then a upgrade to ignition in the form of magnecore leads and better plugs, add a superchip and a couple of hours on the rollers you could possibly be up to 145bhp but it would feel much quicker than that. another route people have taken is to remove the exhaust gas recurculation system to stop un filtered air entering the combustion chamber, also a correctly set up on a fse power boost valve will show up a 0.5 bar increases in fuel pressure over 3000-3500 rpm which is the engines main flat spot. possibly if all this was done correctly you could be looking at MAYBE 150 bhp.
if you was to improve the brakes and suspension along with this increase in power im sure you would be very happy with the result.
if you do decide to stick with the 1.8 and std management i have a superchip, powertec ind kit and egr removal kit available that i could send at a discounted rate.
JoeyBoyden
Jan 4, 2024 02:36 PM
ginner
13
Aug 30, 2015 08:40 AM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
